Hello!let me start off by saying I'm Shawn i'm a 16 year old and this will be my first mod I've put on a forum. Some background info on why i'm doing this. Well my favorite show has been American choppers for years!I mean I loved everything from, the planing,the making,and the out come of the bikes and just the shower was amazing.But as some of you may know the show has come to an end on February 11th 2010. So because this was my favorite show why not do a mod about it! The specs are as follow: CPU:Intel core i5 750 running at 3.5ghz currently (temps 28 idle/39 load) GPUowercolor 5850 RAM:4gb(2x2gb) G.skill ripjaws ddr3 1600 MOBO:Foxconn Inferno Katana PSU:Ocz stealth 700watt HDD:750gb Seagate barracuda OPTICAL:Lite-on Blu ray player/Sony dvd/cd burner/player CPU COOLER: Coolermaster hyper 212 plus Still need to buy- 120x2 rad HDD water block CPU water block GPU full coverage water block tubbing coolant anti-kink coils barbs fans other(paint,plexi,mesh,new dremal,nofear/monster,switches,lights,etc) Some of the parts i will be using in this build after 6 hours of prime 95 and wat i overclocked it to
yes but i am debating if i should release it or keep it a secret....i mean seeing stuff happen without knowing is the best
some quick removal of a few things first to go is the 9 hard drive cages!! second is the 140mm fan! more things when i get my parts
after 3 weeks of waiting that parts have arrived!!! i will start work on putting them on the case once i get my new dremal and some fiberglass but i just bought a truck and im taking the gf to a movie saturday so im spent for now
here is part of the inside put together and painted.....thats the american chopper part of it.... and here is the start of the front and the outside which is the orange county chopper part
red/blu/white look great together. Seeing the rest of the stuff you have collected, I really want to see how this turns out. Especially the placement/integration of the tank.
yes I also can not wait. blue / white / red is a very stylish america. especially if you make a few stars
Hey im back!!! Well i been working a lot and my birthdays coming up so been busy. But i did get some work done!! Well i will start here i bought a black and decker rotary tool and Ive bondo the part of the front of the case and then also got a placement idea of the gas tank
well broke alot of my tools so im kinda stuck might see how much a cheep jig saw will cost for me to finsih cutting 3 holes!!!! only after that gotta drill holes and put screws in after that paint!!! then sadly finish this project and then be done for good
