Case Mod - In Progress Completed! 24h Stealth (Livemodding project for DCMM 2010)
Discussion in 'Project Logs' started by der_george, 19 Oct 2010.
  1. der_george
    der_george What's a Dremel?
    30 Jun 2009
    Hey Guys! - this is going to be my little diary of the 24 hour Casemod I built for the DCMM 2010 at the Gamescom in Cologne together with my mate Patrick.
    To start with I want to just say that there aren’t that many pictures of the building process, because we were more interested in finishing than documenting all of our steps. But I will upload all photos I can find. (A TV-crew from a popular TV-documentary series filmed the build process so there are some moving pictures at the end of the this little bit of text.)
    Background Info:
    Patrick and I chatted a lot about modding and other crap whilst we both took part in an online modding contest. We were talking about quick mods and he asked me if I had any ideas for a mod. I sent him some concepts and then Patrick asked me if I want to take part in the 24h livemodding competition at the DCMM with him.
    Preparation:
    Choosing the design was quite straight forward. Patrick really liked the first concept I showed him. I showed him the hardest first to impress him. Well… he liked it. I did some changes to make it a bit easier, but no way did he want to change it. So we would do it the hard way. I knew it would be really tough. But if I come to think about it, it was the right idea.
    So we met up on my teamspeak-server and discussed the whole plan, went through every step and planned it all out. I then worked out the whole design with all the measurements needed for a Coolermaster Elite or Xigmatek Asguard, as I thought it would be very likely that we get a similar case.
    Well two weeks to go the organisers told us we would be modding a Techsolo MO-09
    That wasn’t very good for us, as we had to adapt all the measurements to fit the new case. And we knew that the case would be a load of crap. Well in the days before the contest we went through all the steps again in our heads just to make sure that we didn’t forget a single thing and then wrote some shopping lists and packing lists with what to take.
    When all was bought and packed it was time to go.
    Patrick took a nice picture of his car before he left towards Cologne. :D
    We then both left from our homes to finally meet up in Cologne hoping that the other hadn’t forgotten anything. (Tuesday evening)
    Our Aim:
    Because we had never modded anything together before this case and as it was our first time doing a livemodding challenge our aim was to complete the damn thing. Nothing more. We knew that it was possible on paper, but would it be in real, under pressure? We were also told that a national TV-channel would be filming us so we knew that extra pressure would be on our shoulders. To add to that we were the only new boys on the block, as all the other teams had already taken part in the livemodding challenge before.
    Tuesday night:
    On arrival we had a bit of a „hotel“-shock.. well nevermind ;)
    Wednesday:
    Early in the morning we left the „hotel“ for the Gamescom where we were awaited by the TV-crew.
    Well we got all cabled up with microphones and stuff, then we could unpack all our stuff have a quick blab about the steps for the first day and before we knew it our countdown had started. 24 hours to go. Well 8 hours of modding for this day.
    Whilst Patrick sawed up all the parts for the inner-case, I took part the Techsolo crap. Patrick did his job brilliantly and every piece was spot on. I cut myself on the stupid box. (On the cutout for the I/O panel – which was as sharp as a knife). Only a small cut in my Thumb – not to deep and didn’t really hurt but boy did it bleed. I know the men with cameras on their shoulders really liked it and I could have bet any money on it showing up on the video. Sometime later the case was dismantled, the pop-rivets removed and a plaster stuck on my thumb. Everything still in plan.
    Then we put the inner-case together with the help of some screws and glue. Then we modified some cupboard hinges so that we could use them for the case. After we had got it all aligned I started filing and sanding the inner-case for which Patrick then started cutting out the acrylic parts for. The bottom part of the inner-case had to be filed so that the acrylic parts fit perfectly. And all the other areas where the bottom and top of the case would meet had to be filed and prepared so that it all still works when the paint is on.
    Patrick also drilled the big fan-hole in the front and I drilled all the holes for the cables. I then carried on filing the inner-case, whilst Patrick cut up some acrylic strips for down the sides. When he was finished we glued them onto the case.
    Now we could glue the glue the acrylic parts to the bottom of the case.
    We then finished the day with the most difficult step of the whole build process. The sides and the front. When I designed the case I the idea behind it was to make the front and sides out of a single piece of acrylic sheet. So whilst Patrick cut it out from a big sheet. I set up our bending platform. My idea was to bend the sheet over a heated strip of metal. To make every bend perfect we milled a V-shaped grove along the bending lines. Then we could bend the piece and it was went just perfectly. Just as planned. We then screwed and glued it to the case for it all to dry overnight.
    Our first day went better than planned. We were absolutely on schedule, we had absolutely super build quality and the TV-Crew had not interfered as much as we had feared.
    Thursday:
    Patrick started the day by finishing off the acrylic base.
    Whilst he was doing that I made the harddrive mount in the bottom of the case. When the base was completed I started sanding down all the edges, so that they had the same radius as the ones on the bend on the top. Whilst I was doing that Patrick cut out the acrylic pieces for the top and the diamond shape for the front. When he was done we glued the diamond shape to front with acryfix. Whilst that was hardening we cut out the V-shaped cutouts in the top bit.
    [​IMG] [​IMG]
    Then we taped up the UV-reactive green acrylic so that no paint could get at it, then we carefully glued it to the top.
    Then we could start the second and last bit of bending for the case. The top part had to be bent twice and the bends hat to be perfect to the degree. It went really well and we had all the major parts finished. When that was done we glued the flexlights to the case and I routed the all the cables.
    Now it was time to glue the top to the main part. We made a small mistake doing it so the strong filling glue mixed with the acryfix which should weld the acrylic pieces together. Well it then took ages drying. We needed a lot of UV-power which we couldn’t get from the little cathodes, which usually easily do the job, so Patrick took the case outside so it could sunbathe.
    The very strong stage lighting was causing us a lot of problems when it came to gluing. After the glue had dried we started filling and sanding all the little imperfections on the case. We had to scratch out some of the glue that had mixed on the seam, which hadn’t hardened properly. Then we injected some new acryfix and when that had dried we finished the second day with filling and sanding.
    Friday:
    The last day started the way the day before had finished – to the dismay of the camera crew we spent another couple of hours filling and sanding.
    [​IMG] [​IMG]
    The base was finished first. So whilst I carried on with the top Patrick primed and painted the base.
    A little bit later it was the tops turn. So we could paint it better we quickly improvised and built a stand to put it on. I tried to reflect some of the intense light from the lighting onto the other side using some of the acrylic sheet. The lighting was giving us a real headache. It was extremely hard to get the paint on evenly in the light. But we managed to get it on really well in the end.
    When the base had dried I then installed the Hardware. We let an AMD Athlon II X4 640, a MSI 785GM-E65 Mainboard, a Coolermaster Hyper TX3 and a Cougar SX700 PSU in. Plus another few little bits. A big THANK YOU to the companies which supported us!
    While I was doing that Patrick made the power button. We used an old one from the button from the Techsolo case and modified it slightly by adding an acrylic sheet so that it was a stealth button which you can’t see. Patrick glued a logo onto it which we printed out before we left and just had to cut it so that it fit.
    When the top had had dried I then soldered the wires from the flexlights to a modular PSU cable, which I cut to length, then I braided all the cables and fitted the fan. Then I cleaned up the whole System and tied up the cables.
    We were ready for the final assembly. We took our time, because we still had more than enough time on the clock… we thought. When we were playing with the case we realized, that we had forgotten to add an extra hinge that prevents the case from opening to far.
    Well as you can see in the Video it was a bloody close finish.
    FINISHED!
    We succeeded in finishing in time, which was our aim for the competition. We didn’t have to botch any single thing, which we were extremely proud of, as it isn’t easy in 24 hours. The Case turned out just as good as I dreamed it to be - if not better.
    Here is the Video:
    CLICK HERE TO VIEW!!
    I have added English subtitles. You have to press the caption button in the bottom right corner to activate them.
    We want to thank everyone who supported us:
    Thanks AMD for the Athlon II X4!
    Thanks René from Coolermaster for the CPU coolers!
    Thanks Cougar for the SX700PSU!
    Thanks MSI for the 785GM-E65 Mainboard!
    Thanks Roccat for the Kova + Apuri!
    And I want to personally thank a few more:
    First of all a big thank you to Patrick for the great teamwork. A big thank you also goes to the other competitors for a great time!
    Patrick then took some nice pictures of the case when he got home.
    Here are the final pics:
    And some technical data:
    CPU: AMD Athlon II X4 640
    Mainboard: MSI AM785GM
    CPU-Cooler: Coolermaster Hyper TX3
    Power Supply: Cougar GX750
    Case: Techsolo MO-09
    Outer-case from 3mm cast acrylic
    Lighting: LED-flexlights
    Size(w,l,h): 28 cm, 50 cm, 45 cm
    On the Sunday we had a very pleasant surprise:
    We were crowned „International German Casemod Champions in the 24h Live Modding Challenge“
    We would like to thank the jury and the organizers for this honor! (and for the nice trophy)
    To be continued:
    Thanks for reading if you got this far! Hope you liked it a bit. I enjoyed it a lot.
    So long
    :0)
    bulldogjeff and stonedsurd like this.
  2. Benzaa
    Benzaa apologizes for his English!
    31 May 2010
    Sehr schön gemacht! Das Konzept und die Ausführung gefällt mir sehr gut! :)
    Das Video geht leider nicht :(
  3. stonedsurd
    11 Mar 2009
    Bloody magnificent work!
  4. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    Awesome work, well done lads.
  5. mecblade
    mecblade 14 year old Technophile
    12 May 2010
    woaah! diesem Fall sieht wirklich cool aus! Es sieht ein bisschen wie ein Stealth-Flugzeug wie der F-117 Nighthawk, aber mit einem Citroen Logo hinzugefügt.
    :D
    i hope google translate didnt muck up :worried:
  6. Attila
    Attila still thinking....
    22 Feb 2008
    Fantastic guys! :thumb:
    A cool case and in only one day. Hats off. :)
  7. bulldogjeff
    2 Mar 2010
    Thats bloody good going for a days work, nice one lads+ rep
  8. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    Impressive especially in so little time
  9. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Great job guys too fast and too good!! ;)
  10. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    love it congratz
    wolfie
  11. Combatus
    16 Feb 2009
    That's a brilliant looking mod in anyone's eyes but having done it in 24hrs is amazing! Well done!
  12. der_george
    30 Jun 2009
    Wooaah guys! One million thanks for the nice comments! I hardly ever read that many nice comments in a thread - and it's my own. :D Can't say how happy I am. :0)
    Dankeschön! Jetzt sollte das Video gehen.
    Thanks mate! Thanks for the reputation!
    Thanks a lot!
    Google Translate did a good job. I understood everything. Yeah it should look a bit like an F 117. But the top wasn't suppose to look like a f*ing Citroen logo. :D
    Thanks Attila! Well not quite one day really. Three days à 8 hours.(and cleverly using the two nights between for drying :D). But 24 hours of real work - so suppose you could call that a day. ;)
    Thanks alot bulldogjeff! Thanks alot for the reputation!
    Thank you Fabou!
    Thanks AnG3L!
    Glad you like it wolfie! Thanks a lot!
    Thank you very much Combatus!
    Thanks again for all your really nice comments guys!
    So long
    :0)
  13. =WBG=cpt_custard
    =WBG=cpt_custard ferret
    29 Jul 2009
    if that was done in 24 hours guys id really love to see what you could come up with in 24 days very very nice work
  14. Paradox42
    Paradox42 What's a Dremel?
    15 Oct 2010
  15. der_george
    30 Jun 2009
    Hey Guys an Girls,
    Got a small update for you today.
    First of all the case got a little feature on casemodblog, which I find really cool.
    Well let’s get on to business. If you read the first post you would have noticed, that there are two cases. Well one of them isn’t finished, well and that’s that I am doing. Today I just sanded down the case and filled a few areas und sanded them again… (some again and again and again ;))
    Pictures Before:
    I also cut out that stupid mesh stuff in the back of case:
    Well as you can see I didn’t have many problems sanding down the bottom part. The top was a bit more difficult. So I had to come up with a stand. But I wasn’t going to spend a single cent on something I will only need for one case:
    Took like 2 minutes to make. 3 woodscrews, an old Ikea shelf bit, four rubbish plastic wheels so I can turn the whole thing whist sanding and painting and an old headrest from a bed.
    It works. (Very well actually)
    Whilst I was browsing the web I found something very very interesting. Check out for your selves:
    I didn’t know what to think at first and I was quite shocked, but that is probably the best compliment you can get if someone likes your work so much that he has to copy it.
    Also found something on a Russian site by chance. Don’t know what they wrote, because I don’t do Russian, but it’s very surprising how far the stuff spreads even without you knowing.
    It probably was the most boring post you have ever read, but thanks for doing so. :0)
    I got a teaser to try to make up for it a bit
    So long
    :0)
  16. der_george
    30 Jun 2009
    Woops, sorry guys, didn't see that someone had posted.
    Thanks a lot. Well it took quite a while to come up with ;) Just didn't tkae long to build. If we had 24 days, well, it would have to be a lot more complex and have more details. (A lot more :D)
    Thanks mate! Thanks for all the nice comments!
    So long :0)
  17. der_george
    30 Jun 2009
    Hey,
    It’s me again. Got another small update for you. Well it’s not going nearly as quickly as the first one because I am building this one on my own now. But what loses the most time is the pretending to work and study bit.
    Okay.. well you probably don’t care much, but the second case will get a different paintjob. Well I planned to do the paintjob which will be on the second case on the DCMM-Case. Well just before we left for cologne the company who wanted us to use their paints suddenly went quiet and then never sent us the promised paint. So we quickly had to get some colour, so we just bought some black.
    Well now it should be interesting to see if the case turns out as good as the first, or maybe even better. At least now I can take my time painting it, as I don’t have the clock running against me.
    The top will be a greyish colour and the bottom will be black.
    Now after the first coat it looks like this:
    I really like it.
    Now just have to wetsand it and add another couple of layers. Then electronics and assembly, then done.
    Thanks for reading!
    So long
    :0)
  18. der_george
    30 Jun 2009
    I know its like the 4th post in a row but I just noticed that I had never showed you any finalpics of the second version.
    So I quickly took some:
    So now the project is officially finished and the thread can be buried without me having a bad continence.
    Thanks for your interest if you are reading this!
    So long :0)
  19. bulldogjeff
    2 Mar 2010
    I love the shapes an angels on this one, it gives it a very futuristic look.
  20. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    :duh: I missed this project!!
    Fantastic work guys :clap:
    I fall in love with your plexi bend machine :rock:
