Graphics Upgrading on a budget
Discussion in 'Hardware' started by mr.a2008, 25 Aug 2011.
  1. mr.a2008
    mr.a2008 What's a Dremel?
    3 Aug 2009
    Hey guys!
    I was wondering what GPU should I get on a Students budget that would be good for dual screening plus playing games at the same time!
    My current card is the GeForce 8600 GT 512MB.
    Since I am a student I dont really have that much money to spend on the card so would be greatful of the advice. As there are loads to go for. Also when the machine is not being used I am going to be FAH on the GPU and the CPU. So any advice would be greatful!
    Also I have a slim line machine from Hp, its the pavillion slimline s50000 . Is there any graphics cards for this computer type?
    Thanks Guys! :D
  2. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    Not really a card for gaming but: Low Profile GT430
    You will struggle to find a decent card for gaming that is low profile.
    You may be best off with a new case so you can fit a full size card.
    If you havent upgraded already your PSU will probably need replacing too.
  3. mr.a2008
    3 Aug 2009
    Cool, thank, I do have a Full size case machine so I can get a full size card really.
    So for the silmline case you would think that I'll have to get rid of the case and get a new one to get the graphics in then?
    Since i am looking for one for a full size case and a slimline case.
  4. mrbungle
    20 Sep 2004
    Your a bit stuffed.
    That slimline has its own little motherboard, not sure its even of a atx standard, I know the psu connector to it is not standard.
    Your going to need a semi decent psu, graphics card and prob motherboard.
    Might not be worth it.
    Whats your budget.
  5. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Go second hand.
    I have:
    Q6600
    4GB DDR2
    HD4870
    Mobo
    All for £142 and all second hand.
    Its the cheapest way to go:thumb:
  6. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    +1 on going second hand... and since even some of the old DX9 cards are faster than the 8600GT (7900GTX, X1950XT), you'll be amazed if you get some of the newer hardware. Even an ATI 4850 would be a big step up from an 8600GT, but it all depends what your budget is. Going by ebay completed listings, the following is what you can expect to pay for a reasonable upgrade, even though they sometimes fetch more:
    ATI 4850 - £35-40
    ATI 4870 - £45-50
    Nvidia GTS250 (same as 9800GTX) £35-40
    Nvidia GTX260 - £50ish
    Nvidia GTX460 - £85ish, depending on memory size
    As the other guys have said, what's your budget? And what's the rest of your hardware? You'll need a beefy PSU for the higher end graphics cards, but not for a 4850.
  7. mr.a2008
    3 Aug 2009
    Damn, thats disappointing! Big style about the slimline!
    My budget is about £50-£60
    Current Rig
    Q6600
    4GB DDR2
    8600 GT 512MB
    2x 1TB Internal
    1x 1.5TB Internal
    1x 1TB External
    DVD-RW Internal
    1x 24" Monitor
    1x 15" Monitor
    PSU 580W
    Its ever since I have added the extra monitor that I have noticed the FPS drop. So it has to do with the GPU really. Just need a better one than current!
  8. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    If all you want is better then get an ATI X1950XT or a 7900GT or GTX on ebay for £20. No offence but the 8600GT is not a good card at all!
    If you want A LOT better, then go for an ATI 4850 or an Nvidia 9800GTX/GTS250 for about £40. Beyond that you'll probably find yourself needing a better PSU; generic PSUs with high wattage tend not to have sufficient amperage on the 12v rail(s). :thumb:
  9. Nealieboyee
    14 Aug 2009
    You may have to increase your budget by about £10-20. You can pick up an 8800GTX for about £35. A 2nd hand psu (400w or so) will cost about £25-30.
    Its too bad you don't have enough posts to join the marketplace. Some fantastic deals on there. My 4870 was £37 incl. delivery.
  10. mr.a2008
    3 Aug 2009
    Hmmm by the looks of it i'll have to get two things then! How many posts do i need for the marketplace? So most of you are in agreement that a 4870 is the best option? Any good choices in Nvidia or is that pushing my luck?
    I've just found an old old PSU in the attic of my parents house that i could use! 230W. That shoud surfice the power outage!
  11. Nealieboyee
    14 Aug 2009
    Doesn't have to be a 4870. It can be an 8800GTX (slightly cheaper) or similar. You need 75 posts i think.
    That PSU does NOT have enough power! Pleeeeease don't use it!
  12. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    8800GTXs are actually still expensive (some idiots still think it is the "King of GPUs" :wallbash: )... a 4850 is better than an 8800GTX anyways, usually cheaper, can have 1GB of vram, and has a much lower power requirement. The 8800GTX is a relic now... power hungry and slow.
    4870 or GTX 260 are a considerable step up again and will go for about £45-60, but both require more power.
    No matter what GPU you choose, you will need at least a 500W PSU, preferably a good one with 18A on the 12v rails.
  13. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Doesn't need a 500W PSU.
    430 builder series will be more than fine.
  14. mr.a2008
    3 Aug 2009
    Ah ok, fair enough but isnt the 8800 GTX just the one up from mine though? Both look good though.
    It isnt enough to just run a GPU with nothing else to power? Well that sucks! :(.
  15. Nealieboyee
    14 Aug 2009
    The 8800GTX is quite a step up from the 8600 IIRC.
    For reference, my psu is a 450W Corsair, and it handled a 6870 with plenty of breathing room.
    mr.a2008 likes this.
  16. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    500 is a nice round figure... I just didn't want to be overly pedantic; at the end of the day most low wattage PSUs are in the same price bracket anyways so it doesn't really matter, be it 437.16 watts or 500 watts. :D
    The problem with low wattage PSUs is that most of their amperage is on the 3.3v and 5v rails, so the 12v will have nowhere near enough juice for a GPU even though the total output is over 200W. I have a 300W PSU lying around and the 12v rail maxes out at 10 amps = 120W peak LOL.
    And as Neal says, the 8800GTX is a HUGE step up from the 8600GT.
  17. mr.a2008
    3 Aug 2009
    Ah ok thanks guys! I'll be on the look out for a second psu and a gpu on either ebay or something like that! Once again thanks for the help!
  18. Elton
    23 Jan 2009
    If you can find a HD4850 or a 9800GTX+ go for that instead of the 8800GTX. The GTX is quite a considerable power hog compared to the other two.
    Also grab a better Power supply please.
  19. Bede
    Bede Minimodder
    30 Sep 2007
    8600GT is a great card, it runs Bad Company 2 at ~25fps on our home computer, and has been running without a hitch since a month after its release. I feel very defensive about my underdog card, be nice :p
  20. mr.a2008
    3 Aug 2009
    i have found that it is a really good card but can't deal with a dual screen of 24" 1920x1020 with a 15" 1024x780. When playing a basic DoW:Dark Cursade i get less than 10fps now. Used to get about 40 fps for a really smooth game play!
