Modding Ribbon cable to VGA/DVI?
Discussion in 'Modding' started by jessieqwert, 24 Dec 2008.
  1. jessieqwert
    jessieqwert What's a Dremel?
    24 Dec 2008
  2. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    Unless you know the pin-outs, that is going to be very very difficult. Check out the laptop LCD thread which you should find in the stickies, it will give you an idea of how difficult this may be.
    Laz
  3. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    That does indeed look tricky. I was thinking IDE ribbon cable, not that tiny thing. Just making the contact connections looks daunting, let along finding the pinout.
    As von lazuli said, check the guide stickies in modding for LCD info. You can also try pinouts.ru for pinouts, though I'm not sure what luck you'll have with that unless it's pretty standard.
    Let us know how it goes and good luck...
    oh yeah, and welcome to bit-tech! :D
  4. jessieqwert
    24 Dec 2008
    Thanks for all the help - here are the pinouts for vga and my lcd. I don't see the corresponding connections. Am I missing something?
  5. TotalEntropy
    TotalEntropy Coming soon...
    26 Nov 2008
    More than likely the LCD has a controller board. Without that board, it's useless.
  6. capnPedro
    11 Apr 2007
    Most likely the controller will have an input for S-Video or Composite (RCA) though.
