Electronics Relocating the PCIE
Discussion in 'Modding' started by Boxcarr, 18 Apr 2014.
  1. Boxcarr
    Boxcarr Will use any tool available.
    3 Dec 2009
    Has anyone out there attempted to try to relocate the PCIE port to the other side of a motherboard?
    Are the terminals on either side of the card interface leading to the same place? I know even trying to do so would likely result in bricking both the motherboard as well as whatever card you plug into it, but I still have to wonder.
    honestly, I blame WC'ing for me even thinking such a thing. All those gorgeous looking blocks from CPU and motherboards all hiding in the shadow of the massive videocards...
  2. Jay88018
    Jay88018 What's a Dremel?
    5 Sep 2012
    Not the same thing, but one of my friends used a pcie extender cable to relocate his G/C in his case, he was only aircooling, so he had to mod his case for the card to vent, but it looked good ( something different), I imagine if your watercooling you could put the card anywhere you want.
  3. Yaka
    Yaka Multimodder
    26 Jun 2005
    i think the back terminals are the same, some years ago i cant remeber 100% which forum i think it was on hexus, some one revered the agp port in that way for a htpc project which he needed for his radeon AIW card
  4. Nexxo
    23 Oct 2001
    I'm not sure how that is going to work. Even if you move the connector on the motherboard to its other side, you'd have to flip the GPU card over to insert it, which means that all its connections are upside-down relative to the motherboard.
  5. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    PCI-E pins are not all mirrored. It won't work. There are things you can remove/remote, but that's not one. Use a shielded extension.
  6. johnim40
    johnim40 Minimodder
    23 Apr 2009
  7. Nexxo
    23 Oct 2001
    Nope, they are for bitcoin mining purposes. The bandwidth won't be enough for a GPU card functioning as GPU card.
  8. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Talking with a lot of experience of soldering very small ICs with large pin counts you'll never do it!
  9. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Speaking theoretically and I don't think this will work but can he use one of these with the PCIe connector soldered to the underside of the mobo to reverse the lanes back?:
    I know nothing about the PCIe topology.
  10. KayinBlack
    2 Jul 2004
    Nope, signal attenuation most likely.
  11. DarthBeavis
    DarthBeavis What's a Dremel?
    29 Aug 2008
    ribbon is best [​IMG]
