Planning Low cost CNC , Design by iD2
Discussion in 'Modding' started by iD2, 14 Feb 2016.
  1. iD2
    iD2 Minimodder
    25 Mar 2012
    Project :: Low cost CNC
    Design by :: iD2
    My blog :: iD2CNC.com
    Machine spec (iD2CNC V.3.0.1)::
    - Working area 45x65x15cm (X,Y,Z)
    - Machine size 62x102x65cm (X,Y,Z)
    - Ball screw all axis 16mm
    - Linear rod rail all axis 16mm
    - Water cooled spindle or wood router
    - Aluminum 5083 + aluminum t-slot
    - Standard support all axis
    Machine spec (iD2CNC V.3.0.2)::
    - Working area 65x65x15cm (X,Y,Z)
    - Machine size 85x102x65cm (X,Y,Z)
    - Ball screw Z axis 16mm
    - Ball screw X,Y axis 20mm
    - Linear rod rail Z axis 16mm
    - Linear rod rail X,Y axis 16mm
    Design ::
    iD2CNC V.3.0.1 [Working area 45x65x15cm (X,Y,Z)]​
    iD2CNC V.3.0.2 [Working area 45x65x15cm (X,Y,Z)]​
  2. RooiDuiwel
    RooiDuiwel What's a Dremel?
    20 Sep 2009
    I know I should ask this rather on a CNC forum, but do you think it would be possible to use a 110V router on 240V electrical with the use of a step-down transformer?
  3. asura
    asura jack of all trades
    22 Apr 2009
    Yup. 110v is the standard for the construction industry. Have one of these myself.
  4. iD2
    iD2 Minimodder
    25 Mar 2012
    Yes , it can use. i used to use step-down transformer and it work well. (sorry for reply late)
    thank :D
  5. RooiDuiwel
    20 Sep 2009
    ah dammit, that should have been WITHOUT :(
  6. asura
    22 Apr 2009
    Forgot to think - check frequency too. Brain fart, sorry.
  7. Cheapskate
    13 May 2007
    Yes, but only for a short time. It will burn through the brushes at an incredible rate before it's fiery demise.
  8. RooiDuiwel
    20 Sep 2009
    ok so with something like This where would you run it?
    as in, would you place it directly between the router and all the electronics or would you place it directly coming from wall and set up the cnc as a 110V system?
  9. asura
    22 Apr 2009
    That would entirely depend on your long term plans...
    If you plan on remaining in a 230V area for the foreseeable future then I'd leave only the router with 110V. Whereas, if you plan on moving (I presume back) to a 110v area, then it makes more sense to make everything 110V at the moment and run it all through the transformer. That way when you are again 110V you don't need to worry about your control equipment - though I suppose you could run it through the transformer stepping up rather than down...
    However - you can get a decent 230V router (or a couple of cheep ones) for the cost of that transformer...
  10. RooiDuiwel
    20 Sep 2009
    hahahaha, my newbness was in such a hurry that when I bought it (imported), I never looked at the operating voltage :duh:
    guess I'll just stick to my original plans for it to be used as a wood router in a custom made table
    thanks for the info guys
