Resistors. I want to place a simple 10kOhm resistor on my schematic/board....which one should I choose from the hundreds of resistors available?
Discrete, ResEU-5 (only diff between ResEU and ResUS is the symbol used). Not sure about the diode. I'd recommend finding the exact type you need, and then put down the generic diode entry w/ the appropriate grid size, then just name it the same as the diode you need.
Thanx Yeah, I've now come to realize this is only a layout program, not an actual circuit tester....right?
Ok...again...is there a symbol for the molex power plugs inside our computer? the panel mount ones??? I see a molex category, but I don't see one that looks like what I need.
HELP Its the only thing I'm waiting on now! Also...fan headers....are there any fan headers in there??? grrr...hehehe.
