At the moment when I run FAHControl it just sits there saying connecting, but there is an FAHClient running. See top below: Code: PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 6518 fahclien 39 19 492m 68m 2960 S 696 0.4 35:40.94 FahCore_a4 If I then click on start within FAHControl I will end up with two FAHClients running at the same time. The newly started one by my user and the one that is running from boot up by user fahclien. Code: PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 6518 fahclien 39 19 492m 68m 2960 S 562 0.4 43:44.44 FahCore_a4 6673 john 39 19 434m 57m 2948 S 213 0.4 0:31.85 FahCore_a4 If I run sudo kill 6518 it just keeps on restarting itself. I did try and uninstall FAHClient and reinstall it, but it still does the same. Any suggestions?
Which Linux are you using? I think it makes a difference to what you have to do... In Ubuntu 12.04, I installed FAHClient first, then FAHControl, and everything worked perfectly out of the box. That's how Stanford and others say to do it. I don't know what the effect is if you installed FAHControl first, but that may cause the same sort of problem as you are seeing. Certainly uninstalling FAHClient then reinstalling would be the same as installing it after FAHControl.
Strange thing is its been working perfectly until this weekend. Only change is a new router and a new IP address range. I wouldnt have thought that would have affected it.
