my new custom pc!! The case is a BitFenix Neos (for which I thank BitFenix Italy!) That I will be marketed in more colors. The version I chose is all white .... Here are some photos
I will mount a liquid cooling with 360mm rad and airbrush it!! the power supply is a Bitfenix Fury 750 G
To fix the radiator 360 mm (which will be supported by 6 fans) in case I had to do some modifications to the compartment of the unit, adding some support
I went with the top and I ADDED some more details on the inside of the case! and removing the grille on the front panel I found two nice holes 12 cm for the fans that I can taste very !! ps: the white disappear
some fan in the theme !! Anche il mouse e la tastiera saranno in tema... The mouse will be the Corsair M95
I have seen several cases made from wood, a few that applied wood veneer or vinyl wrap, but yours is the first wood painted case I've seen. Fantastic work.
