Windows Windows 8.1
Discussion in 'Software' started by happyhammer7, 13 Oct 2013.
  1. happyhammer7
    happyhammer7 What's a Dremel?
    19 Oct 2009
    *Edit*
    Previously started this thread regarding an issue I originally had. Now it's resolved, this thread can be used to discuss all things Windows 8.1. :)
  2. happyhammer7
    19 Oct 2009
    I have just restored windows 8 and ran scan for new hardware and it works fine. So it can't be any particular hardware faults.
  3. Nexxo
    23 Oct 2001
    Well, that's why it's called a beta release. :)
  4. happyhammer7
    19 Oct 2009
    I thought it was the full release version that will be available from next week,???
  5. GoodBytes
    20 Jan 2007
    Windows 8.1 is officially released Oct 21st.
    Also, for next time, be sure to Uninstall your security software, if it's not Windows Defender of Win8, BEFORE doing the upgrade. A/V solutions can block the upgrade form being successful.
    In addition, you should wait for Windows 8.1 drivers. The kernel was updated.
    You may also need to update the BIOS.
  6. happyhammer7
    19 Oct 2009
    I didn't upgrade Goodbytes as I did a clean install. Going to stick to Windows 8 for now then upgrade when it's officially released.
  7. SpAceman
    SpAceman What's a Dremel?
    1 Nov 2010
    The DreamSpark version is RTM. I'm using it on my laptop and desktop.
  8. GoodBytes
    20 Jan 2007
    RTM is not final.
  9. ComputerKing
    8 Sep 2006
    Really ?! I just downloaded it and I can't see anything telling me it's RTM :(
    copy name : en_windows_8_1_x64_dvd_2707217 (3.8GB)
    is that the final copy or i will be re ordering it from dreamspark again ? :duh:
  10. ComputerKing
    8 Sep 2006
    Confirmed :( Just tried that dream spark copy with VW and I'm disappointed
  11. GoodBytes
    20 Jan 2007
    RTM is release to manufactures for testing. It means that the OS isn't ready yet.
    What's happening is that Dell, HP, Acer, etc.. takes Windows 8.1, and makes sure it passed some rigorous testing, for the current supported systems. At the same time, Microsoft does it's own rigorous testing as well. Any fixes, depending on the seriousness will be day 1 patch available on Windows Update, or execute within the setup process at the end, or patch the OS itself,. (usually, it's day 1 patch)
    At the same time, Microsoft continues to work on the OS. But usually things that don't relate to the OS itself, like the programs that it comes with it. In most cases, there isn't much to do, but this time there is, because Microsoft not only presented updated apps, but also new ones. That is why Microsoft decided not to release it for MSDN/MSDNAA/DreamSpark/TechNet initially. They didn't want to see reviews going like "This and that is broken, Win8.1 sucks", as they continue work on them.
    Changing that decision is risky, but so far, it's going well.. no one cares about this build to attack clicks from the news media, people want the final official version.
    ComputerKing likes this.
  12. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    GoodBytes
    Usually the sense of reason or one of the normal ones anyway.
  13. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Just to echo what GoodBytes said, there has already been one QFE's released since RTM that weighs in at 200Mb for x64, and 100Mb for x86 and contains no less than 658 updated packages.
    People are also expecting another QFE either on or shortly before GA, so a lot has already changed since RTM.
  14. timmehtimmeh
    timmehtimmeh Minimodder
    2 Jan 2005
    12pm has been and gone, it was meant to be launched 13 minutes ago ... but hunting around on
    https://www.google.co.uk/search?q=where+to+download+windows+8.1+update
    is not helping?
    I tried the link on http://windows.microsoft.com/en-gb/windows/buy?ocid=GA8_O_WOL_Hero_ShopHP_FPP_Null
    but I dont think that is the update?
    Hmmmmmmm
    according to http://www.theinquirer.net/inquirer...windows-81-update-lands-at-12pm-uk-time-today
    I should be able to get it already. Windows update does not show any update to download.
    Anyone found a link yet for the update for windows 8.1 final?
  15. RedFlames
    23 Apr 2009
    it's in the app store... not WU, currently d/ling it now
  16. GoodBytes
    20 Jan 2007
    Like service packs, Microsoft is releasing is in section.
    Depending on your product key and region, it will be sometimes today.
    4 a.m Pacific Time Oct 17 is the official release time.
  17. GoodBytes
    20 Jan 2007
    When I posted above there was no notification, in the app store.
    I had a look now, and boom it's here. Big huge, screen size button: "Upgrade to Windows 8.1"
  18. timmehtimmeh
    2 Jan 2005
    ah thanks! downloading now :)
    2%
    but why in the app store and not windows update?! :(
  19. K3TT
    K3TT What's a Dremel?
    28 Jan 2008
    Still nothing yet. Windows 8 Enterprise
  20. wolfticket
    19 Apr 2008
    To remind people the Windows Store exists? :)
