Hello, im from Turkey. This is my first mod. I dont have lot of money and dont find any sponsors so my mod is not going to extreme build. First of all i use my old build. CPU i5 4670k Ram G skill 8 gb Motherboard gigabyte z87x d3h Vga Sapphire 7870 oc Psu cooler master gx 750 w and i use chineese or second hand water cooling parts. And i use pneumatic fittings and tubings. Also use car radiator.
I bought a car radiator and spray it. And welding 10 mm copper pipe on in and out holes. And using pneumatic fitting on it. Look great And bought fans blocks liquids and fan grills.
Today i'm drawing the desk on pc. And print it and give my friend and we wait now. We use 2mm aluminium.
Do you have any more pics of the desk itself being constructed? Was it all a single piece that was just bent & folded? How did they do the edges? Is it bar or is it all bend/wrapped to produce that lip? Looks really well done.
