A question guys, how thin a sheet of acrylic at about 480mm by 350mm to bend round at about 410mm radius. Without undue force for the front of my Case cheers in advance
You want to bend without heating? I'm not sure if they make polycarbonate sheet thinner than 1/8" but a 1/16" sheet would be perfect since it's pretty flexible. You could pull this off with 1/8" maybe, if you are sliding it into a groove, but the force will be right on the border of "undue".
fits For info 2mm plexy bends fine at this curve not much force at all. Ok you can't see much cos it's see through. But it is there.
