News AMD points to multi-GPU advances in Mantle, DX12
Discussion in 'Article Discussion' started by Gareth Halfacree, 3 Feb 2015.
  1. Gareth Halfacree
    4 Dec 2007
  2. DbD
    DbD Minimodder
    13 Dec 2007
    This is marketing fluff. You can't share memory between the gpu's, so each card still needs all the resources in memory which for any game is basically the same stuff (textures, etc). Just cause you can theoretically put some stuff in only one gpu's memory and not the other doesn't make it useful most of the time.
    Even if you could find some use for this and lets say it gave a 5% performance boost which games company is going to bother coding and maintaining this? Exactly what % of their customer base would benefit - the numbers using mantle enabled cards in Xfire is a tiny % of the number that could buy the game. Then you've got to think of that tiny group how many wouldn't have bothered buying the game but now will buy it cause it runs 5% faster on their Xfire setup? The extra money they'd generate by doing this is insignificant and certainly doesn't come close to the costs of implementing and maintaining it.
  3. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    This reads to me like a return to 3dfx's original definition of SLI, where GPU A draws all the odd-numbered lines, and GPU B draws the even ones.
  4. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    Indeed as I thought too. This halves the amount of pixels that are required per frame in essence halving the vram requirement and giving the same effect as doubling the vram available per pixel rendered.
    Will be interesting to see the end result I think
  5. Parge
    16 Jul 2010
    Carmack has talked about doing this for Oculus Rift. From what he said its brilliant if your displays refresh rate is high enough.
  6. Gareth Halfacree
    4 Dec 2007
    Ahem:
  7. andrew8200m
    4 May 2009
    Its funny because I missed that entire last bit off :D
  8. rollo
    rollo Modder
    16 May 2008
    Also had major flaws if the game was not coded for it from the ground up. High display refresh rate was also more cheaper and available in the time when 3dfx did it.
    These days a 120hz display from a decent manufacture will cost a decent chunk of cash. Or you can pick up the same size screen with 60hz for half the cash in most cases from the same manufacture.
    Also issues with 4k as it can bearly drive a 60hz panel let alone a 120hz one. Even 2 980s are not enough for 60fps in most modern games without sacrafices.
  9. fellix_bg
    fellix_bg What's a Dremel?
    21 Sep 2005
    3Dfx's SLI technology actually duplicated the texture data for every card in the system. Only the frame-buffer content was unique and thus could render at higher resolution without performance drop. Data duplication is the default mode for every unmanaged remote/split-memory system out there.
  10. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    In my defence, I claim lack of caffeine :duh:
  11. forum_user
    forum_user forum_title
    4 Jan 2012
