Build Advice Resetting After an Hour
Discussion in 'Tech Support' started by contrastinglight, 1 Mar 2012.
  1. contrastinglight
    contrastinglight What's a Dremel?
    18 Mar 2011
    I am having an issue with my new build which was put together this week, after 45 minutes to an hour of running it will reset its self and continue to do so after another couple of minutes of running.
    I also noticed that when I click to shut down on the log in screen it will do the same thing, reset and restart.
    I have windows 7 installed on the master drive ssd- this has been updated, all the drivers have been updated - bios have been flashed to the most current - the memory on the mother board passes the bios test and can all be seen in the bios.
    The cpu temps seem to be fine when I check in the bios even after the 1 hour reset, I have cleared the cmos and still nothing is fixing this issue.
    I am currently thinking short and will probly start checking the screws and MB for any contacts ect?
    Any advice is welcome.
    Richard:wallbash::wallbash::wallbash:
    Set up-
    CPU i7 3630 MB Asus Sabertooth LGA 2011 Saphirre Radeon 7970
    16gb Corsair Ram Cooler Corsair h100 asus sound card
    Case Corsair R 500
  2. KidMod-Southpaw
    28 Sep 2010
    Is that SSD a Crucial M4 by any chance?
  3. contrastinglight
    18 Mar 2011
    It is how?
  4. contrastinglight
    18 Mar 2011
    Crucial M4
    I have since done some research on the crucial m4 and have updated the motherboard chipset drivers, the m4 firmware and also moved the sata connections from the Marevell to the Intell Sata- Howver this problem still keeps happeneing 45 minute running time and the pc starts to reset.
    :wallbash::wallbash::wallbash::wallbash:
    Any help or advice welcome,
    Cheers,
    Richard
  5. Deders
    Deders Modder
    14 Nov 2010
    have you tried taking the side of the case off?
  6. contrastinglight
    18 Mar 2011
    The side of the case has been off the majority of the time, since I reset the cmos.
    The temps in the mios are all reading 27/28 the MB 31, so I dont think it is an over heating issue.
    I am thinking of removing the ssd drive and try a fresh install of windows 7 on a spare 2.5 I have, to confirm it is the SSD drive.
    Failing that it will be back to basics and remove the MB from the casing and take it from there......
    cheers,
    Richard
  7. Deders
    Deders Modder
    14 Nov 2010
    Could be faulty PSU, can you switch it with another?
  8. contrastinglight
    18 Mar 2011
    Unfortunatley I dont have another one spare, I will try a differrent hard drive intially to rule it out- then strip out the machine.
    cheers for the reply,
    Richard
  9. contrastinglight
    18 Mar 2011
    Help Now with memory errors
    Okay whilst about to re install windows on an alternate hard drive, i have run memtest off a usb - This is currently showing over 15104 errors at just 51 %
    Is this going to be the main cause of my restarting issue??:eyebrow:
    Thanks for any help,
    Richard
  10. Deders
    Deders Modder
    14 Nov 2010
    I have a feeling that might have something to do with it. :duh:
    What is it set to? MHZ, Timings and Voltage?
  11. contrastinglight
    18 Mar 2011
    I had to ask the obvious question for my sanity:blush:
    After one pass I had over 20000 errors -
    The memory is corsair vengeance 1600 set at auto in the bios which has it at 1333mhz 9-9-9-24 the voltage is 1.5 again on auto again.
    Do I need to change the MHZ of the memory to 1600 or would this not make any difference to the errors?
    Sorry for the noob questions, first build....:duh:
    cheers,
    Richard
  12. Deders
    Deders Modder
    14 Nov 2010
    Ok are those should be pretty safe timings and frequency, Are all the figures on the side of the Ram correlate with the ones in the bios?
  13. contrastinglight
    18 Mar 2011
    Hi, the Ram frequency and timing corrolate to the figures on the side of the ram.
    I am now unable to make post and an Led light has now appeared on the MB indicating the ram memory issue.
    I have now made contact with scan to get an RMA........
    cheers,
    Richard
  14. contrastinglight
    18 Mar 2011
    So Have some new Ram after an RMA, which is in place and has been mem tested and passed.
    Booted up and worked away for 10 minutes and it rebooted.
    Gonna try a different hard drive and also test the GPU to if its causing the issues.
    I had mem test running for an hour and 30 minutes and it hadnt reset could it still be a power issue?
    cheers,
    Richard
  15. rollo
    rollo Modder
    16 May 2008
    you need to set xmp for the memory first and formost its a profile to set the correct timings
    its unlikely to be a short as it just wouldnt boot
    This could be a lack of power issue
    try running prime 95 and see what happens
  16. contrastinglight
    18 Mar 2011
    Help
    So Tried to install windows on another hard drive however due to previous MBR on the disk....... it wouldnt installl, tried to flatten it with active Kill Disc off Hirens boot disc- this did not work due to an error.......... Back to the drawing board on that one...
    Booted back up into windows 7 ran speed Fan to see if there were any issues, it is coming up with a cpu Temp of 128 c - I cannot believe this, the cores are all reading 28-30 c this cant surely be right?
    What other software can I use to check the temps?
    Mean while I ran the system for a while and it done its thing - rebooted with no BSOD even after I had set it not to automatic restart.
    I booted into safe mode and ran it for a good 20 minutes done some surfing tested it on some video play back, and it worked safely with no restarts.
    This is leading me to think that it is a driver issue?
    I really am getting pissed off with the whole thing, apple was mentioned a few times at the system to try and scare it into working!!:waah::waah:
    My current train of thought is to flatten the ssd card reinstall a fresh copy of windows 7 plus a fresh install of the drivers???
    Any help would be appreciated, :confused::confused::confused::confused:
  17. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    I found Speedfan useless at reporting temps. It was a good 10 or 15 degrees out most of the time compared to CoreTemp or Real Temp. Try using one of those and seeing what they say.
    If it ran fine in safe mode then it's almost certainly drivers. I'd give the format and reinstall a go using the latest drivers from the chip manufacturer i.e Realtek, Intel e.t.c rather than the motherboard manufacturer as they don't seem to update them often. Usually the specification page on the motherboard website or the specification table in the manual should give you enough info to get the drivers direct.
  18. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    you can use diskpart to clear the disk, i do that all the time with troublesome disks
    cmd prompt
    Diskpart
    select disk n where n is the disk no (0) is the first drive (1) is second etc physical disks not partitions
    clean
    that wipes everything including mbr
  19. contrastinglight
    18 Mar 2011
    Thats what I was thinking, glad to hear I am not just clutching at straws....:thumb:
  20. contrastinglight
    18 Mar 2011
    Cheers, Rich will give it a go.......
