Case Mod - In Progress Coolamasta's Home NAS & VM host build
Discussion in 'Project Logs' started by coolamasta, 26 May 2013.
  1. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Hey All,
    Thought I would put another thread together with the progress of my home NAS and VMware host builds, I have both currently built and running but am about to upgrade them both again.
    The first batch of pics in post #2 are from the previous build of the NAS and the post #3 pics are from where I built the 16U MDF rack to hold the kit :)
    Spec of the NAS currently is:
    • 4U Rack mount case
    • MSI H77MA-G43 s1155 Motherboard
    • Intel i3 2120 CPU @ stock 3.3ghz
    • 16GB Kingston Hyper DDR3 RAM (4 x 4gb) @ stock 1600mhz
    • Seasonic G series 360w '80 Plus Gold' PSU
    • LSi 8-port 9260i RAID Controller with 256mb Cache (Need a BBU!)
    • 4 x Western Digital 3TB "Red" (Raid Edition) Harddrives
    • Icy Box IB-545SSK Tray less 5 Bay HDD enclosure
    • Crucial M4 60GB SSD for OS & Plex server
    • WD Green 2TB HDD for general dumping group/PC backups/DL's etc
    • Intel Pro Dual 1000 PT PCIe Server NIC in 2GB Teamed Config
    Spec of the VMware host currently is:
    • Intel i5 3570k Ivy CPU under-volted @ stock 3.4ghz
    • 16GB GeIL Black Dragon DDR3 RAM (2 x 8gb) @ stock 1600mhz
    • 8GB Kingston Hyper-X DDR3 RAM (2 x 4gb) @ stock 1600mhz
    • Antec Greenpower 350w '80 Plus Bronze' PSU
    • 2 x 120GB OCZ Vertex 2 SSD's
    • 2 x Western Digital 500GB "Black Edition" Harddrives in Raid 1 (On-board Raid)
    • Intel Quad Pro 1000 PCIe Server NIC
    Currently the NAS is running a Raid-5 configuration and have 8.18TB of usable space from the 4 x 3TB Red's. I stuck with the default 64KB stripe size and had a play with the read-ahead, read through, write through and write back settings to see what I/O I can get :)
    There is a 120mm inlet fan at low speed, the top panel expansion card arm holder I've modded to hold an 80mm fan to breeze air over the RAID controller heatsink as it gets pretty damned hot!
    Below are the results of the array in a RAID 5 using the following config:
    Stripe Size:- 64KB
    Read Policy:- No Read Ahead
    IO Policy:- Direct IO
    Write Policy:- Write Through (was using 'Always Write Back' but need BBU)
    Access Policy:- Read Write
    I have 1 problem though and that is I don't have a BBU (Battery Backup Unit) installed which means that having the Write Policy set to 'Always Write Back' is dangerous because if there is a power failure then it will most likely cause data corruption and mess up the Raid array and make me a very unhappy chappy!
    I currently have set the Write Policy set to 'Write Through' which will get rid of the risk but it has dropped my write speeds to less than a quarter of what they are above, crazy how much difference it makes! * Update - I now have a BBU which will be added on the upcoming upgrade :D
    [​IMG] [​IMG]
  2. coolamasta
    26 Apr 2009
    The current NAS build:
    The current VMware build:
  3. coolamasta
    26 Apr 2009
    The Rack Build:
  4. coolamasta
    26 Apr 2009
    Some pics of how it currently stands before the servers get stripped down and rebuilt with the upgrades etc :)
    GaryP and The_Crapman like this.
  5. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
    Wow, that looks epic mate! Nice job.
  6. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    Nice job very clean !
  7. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    That looks really neat! good job.
  8. The_Crapman
    5 Dec 2011
    That's a pretty bitchin setup you got there and it's new home looks great. Those louvres looked pretty cool. Where'd you get them?
  9. coolamasta
    26 Apr 2009
    Thanks all, just getting all my new hardware up-together read for the upgrade at the moment :)
    Cheers bud, the louvres were just from B&Q in the ventilation section, don't think they were very expensive to be honest :thumb:
  10. coolamasta
    26 Apr 2009
    Few pics of some of the new hardware for me new VMware host:
    * HP P800 16-channel Raid-Controller, (8 Internal, 8 External) its a bit overkill for what im going to be using it for but as it didn't cost me anything I can live with it :D
    * Icybox Trayless 3-bay Dual channel SAS harddrive enclosure
    * 3 x Seagate Cheetah 15,000 RPM 300GB SAS Harddrives
    * Intel i5 3570k Ivybride CPU
    The current i3 CPU running as my VMhost has done very very well handling my 7 VM's but its not got quite enough puff which is why I'm going for the i5 Ivy, should run faster, cooler and still use little power, but then im sure the 15k SAS drives will help use the power haha.
    Just waiting on the new motherboard for the NAS, then the current NAS motherboard will be used with the i5 to become the VMhost as it has a H77 chipset so better for the Ivy.
  11. coolamasta
    26 Apr 2009
    Change of plan with the 15k drives and HP P800 RAID controller, my entire goal with the NAS and VMware host was to keep the power consumption as low as possible, the P800 RAID card doesn't make a massive difference in power consumption but those 15k SAS drives eat far more power than I expected and the heat they produce outweighs how well the IcyBox can cool them, IE they cant haha so I had to ditch that idea in favour of some SSD's :)
    I've added a BBU to the LSI Raid controller in my NAS and now getting the awesome I/O again without having to worry about corrupt data in event of a power outage, not a lot else change to it besides now its running a Dual Intel Pro1000 Server NIC which is Teamed to produce a single aggregated 2GB link to the switch :D
  12. LegendaryScott
    LegendaryScott Trying to live up to the name
    5 Apr 2013
    Woh, setup is awesome dude
  13. matiss
    matiss Minimodder
    24 Jun 2010
    Some very sweet hardware you got there.
  14. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Great set up. How insane is your electric bill !
  15. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    Looks like an awesome build. I'd love to do something very similar myself so I could hide everything out of the way a little but unfortunately don't have the money to replace everything with rackable gear :(
  16. coolamasta
    26 Apr 2009
    Heres the new VMware host, its now been moved out the massive 4U rack mount case into a 2U instead, now that I have ditched the 15k drives I am running a pair of 120GB SSD's and also a pair of 500GB drives in a Raid-1 for now...
    Some new hardware now being used to keep power consumption low namely an IvyBridge i5 undervolted, full spec is below:
    • 2U custom rack mount case from servercase.co.uk
    • Intel i5 3570k Ivybride CPU
    • 8GB Kingston HyperX DDR3 RAM (2 x 4gb) @ stock 1600mhz
    • Icybox Trayless 3-bay Dual channel SAS harddrive enclosure
    • 2 x OCZ 120GB SSD's
    • 2 x 500GB WD Black HDD's
    • Intel 4 port Pro1000 NIC card
  17. coolamasta
    26 Apr 2009
    Thanks for the comments all :)
    Its not toooo bad to be honest, everything you see in my rack is only pulling 180w at the wall! ;)
  18. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    amazing i want that setup in my cellar but alas i dont know what i would use it for lol.
    what do you do with all this hardware and this setup??
  19. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    Amazingly clean job on the cabling, it's hard to do in a case like this :) :thumb:
  20. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Very nice job with that build. I have a question for you, can you only get the Intel Pro NICs to work in Aggregate? Or is it possible with dual onboard NICs like the one on my EVGA board? I have searched for a way to use them in aggregate but I have not found a solution yet. My google FU may be off.
