News UK follows US in banning larger electronics from selected flights
Discussion in 'Article Discussion' started by Gareth Halfacree, 22 Mar 2017.
  1. Gareth Halfacree
    4 Dec 2007
  2. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    They are concerned that only those 6 countrys might use a laptop(battery) to set fire to a plane? Is that it? I must admit it doesn't seem to make a whole lot of sense to me. Maybe the amount of explosives you could fit in a tablet or such is enough to cause a problem, but a smartphone is too small? But even then..why just 6 countrys? Terrorists can get a plane from any country.
    Am I missing something?
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    At a guess could it be because the security at airports in those countries isn't up to snuff?
  4. Xlog
    Xlog Minimodder
    16 Dec 2006
    But, you are still allowed to carry-on the actual batteries (nowhere does it say that you cant), so that point is moot.
  5. Corky42
    30 Oct 2012
    IDK what needs to be done to battery to make it go bang with sufficient force but I'd imagine it involves doing something to it that would be noticeable, whereas a battery inside something like an ipad could easily be overlooked unless you opened it up or scanned it.
  6. Xlog
    Xlog Minimodder
    16 Dec 2006
    All electronics are x-rayed regardless.
    For battery to catch fire you need to either damage it physically or short it. And imo, dodgy Chinese battery pack is a much bigger risk than anything listed in that ban, yet is totally allowed.
  7. Anfield
    Anfield Multimodder
    15 Jan 2010
    How would the notoriously underpaid and undertrained airport staff be able to tell the difference between a good and bad battery?
    In other words, banning low quality batteries from flights isn't even remotely feasible without banning all batteries.
  8. RedFlames
    23 Apr 2009
  9. Wwhat
    Wwhat Minimodder
    2 Oct 2005
    Clearly they have some info they aren't sharing that makes them decide this, and I'm not sure it's simply a fear for a bomb in the device. But then again, they have done some daft things in the past
    Maybe the idea is to have certain computers out of the owner's hands so they can install hacks while it's supposedly being put into the cargo hold, it could be anything really. But I would not trust any device anymore once it had gone through the process.
