Motherboards Possible dead motherboard- halp!
Discussion in 'Hardware' started by .//TuNdRa, 25 Mar 2012.
  1. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    okay. so earlier today I got tired of all my watercooling kit being sat on tue windowledge and decided to tear it all down and fit it into the case. a while later, after id finished leaktesting; I plugged the power I to my motherboard and got no POST. Crap. Theres also no video output from either of the Gpus. i've tried; all four sticks of RAM in all four slots, checked all connections and contacts, and just now ive torn the watercooling out and im running it all on original air cooling heatsinks. still no luck.
    help with this would be appreciated. I'm stumped. and rather pissed off, tbh.
  2. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    Have you tried taking it out of the case and trying with only the necessary components?
  3. .//TuNdRa
    12 Feb 2011
    Yes. still dead.
  4. Deders
    Deders Modder
    14 Nov 2010
    Damn! No bios coded? Reset bios?
  5. feathers
    feathers Minimodder
    11 Apr 2009
    What was the coolant? Distilled water?
    How old was the coolant?
    If there was no spillage then I wonder if static charge.
  6. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    Double checked the PSU?
  7. .//TuNdRa
    12 Feb 2011
    Coolant was Ek EKoolant, about three months old. No POST codes, no video output. system was assembled on a wooden surface, so theres little to generate static off. I think its fcked.
  8. feathers
    feathers Minimodder
    11 Apr 2009
    I once spent a day fitting PWM, NB, SB waterblocks to my old Asus P5b, power on, nothing, completely dead.
    It seems I killed the mobo either when I dropped the CPU accidentally onto the cpu socket or perhaps it was Henry with his static charge that fried the board. The board was out of case on table when both events happened.
  9. .//TuNdRa
    12 Feb 2011
    Didn't remove the PSU and the only electrical thing near the case was my phone. I'm stumped. I think the rest all still works, but the Mobo does seem to be dead.
  10. law99
    law99 Custom User Title
    24 Sep 2009
    Sounds like a case for a return... no post at all then it's got to be the board if you've removed all other shiz.
    One of my boards wouldn't post the other day... but it was that it didn't like the IDE CD-RW drive.
    EDIT: And even then, at least stuff momentarily came up on the screen. I take it you've tested the psu then?
  11. feathers
    feathers Minimodder
    11 Apr 2009
    Usually mobos are pretty tough things. Although... it was an AMD... Perhaps it's time to change a few bits. :)
  12. .//TuNdRa
    12 Feb 2011
    I was waiting for that. Get me an Intel CPU and mobo for £20 and I might be able to. otherwise; I don't have a Pc.
  13. BennieboyUK
    24 Nov 2010
    I would look at RMA for board if it is not the PSU then... sounds to me like the board is totally bulldozered! (eeek! sry!)
  14. .//TuNdRa
    12 Feb 2011
    The board was watercooled at the time. I doubt my warrenty covers that.
  15. feathers
    feathers Minimodder
    11 Apr 2009
    Hopefully it's just the board. Very rare for other bits to be killed, so u can get another board for your bits.
  16. law99
    24 Sep 2009
    Simple, don't mention the watercooling. I doubt they'll be scrutinizing that much surely? You can totally deny ever having fluids near it.
  17. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    This, just put the old heatsink on, assuming you still have it and they will be none the wiser, I've done it a few times :p
    and sorry if it is your board dude, (it sounds like it to me) I feel for you, I'm having to sell of a load of my gear as my car decided it would be funny if the clutch and timing belt went pop, some Although from what TG suggested and from having a brief look I don't think I need a new engine, I will be swapping the engine for TT and new gearbox, so that's going to be a hefty 4.5k bill :wallbash:
  18. Instagib
    Instagib Minimodder
    12 Mar 2010
    I got flamed in these very forums for suggesting something similar once.
  19. thetrashcanman
    18 Nov 2010
    Really? :s how silly.
  20. Instagib
    Instagib Minimodder
    12 Mar 2010
    Yes, I thought so too. Meh.
    @tundra; don't give up on amd! I've a soft spot for amd too. Nothing beats overclocking on them. Intel are so uniform; put x volts through, you get y frequency. Amd are much more of a challenge I find.
    Is it worth putting the board in the airing cupboard for a couple days in the hope it may dry any moisture out? Can't hurt can it?
