Other DOS on USB stick
Discussion in 'Software' started by wyx087, 19 Apr 2009.
  1. wyx087
    15 Aug 2007
    i downloaded this ZIP file and followed the instructions
    http://download.cnet.com/DOS-on-USB/3000-2094_4-10795476.html
    followed all the steps, except not quite understand this one:
    tryed putting everything into thumb drive, also tryed putting stuff from DOS directory into thumb drive. either worked.
    here's a list of all the files from the package
    Code:
     Volume in drive H is RamDisk
     Volume Serial Number is 0E68-80F1
     Directory of H:\DOS-on-USB
    19/04/2009  22:49    <DIR>          .
    19/04/2009  22:49    <DIR>          ..
    16/02/2008  18:58               783 autoexec.bat
    11/01/2008  22:04    <DIR>          boot
    16/02/2008  19:13    <DIR>          dos
    19/04/2009  22:49                 0 i.txt
    21/01/2004  08:47           442,368 James' Format Tool.exe
    16/02/2008  19:06             2,573 README.txt
                   4 File(s)        445,724 bytes
     Directory of H:\DOS-on-USB\boot
    11/01/2008  22:04    <DIR>          .
    11/01/2008  22:04    <DIR>          ..
    31/05/2003  07:46               625 ATTR.COM
    19/02/2004  12:43               352 AUTOEXEC.BAT
    16/02/2004  17:39            16,374 BOOTPART.EXE
    15/04/1997  03:00            13,520 CHANGE.EXE
    05/05/2003  22:22            94,292 COMMAND.COM
    25/01/2004  13:04               173 CONFIG.SYS
    21/08/2003  19:43                42 CPUDET.COM
    01/10/2002  01:09             4,848 CTMOUSE.EXE
    29/07/2003  19:59             3,020 DELTREE.COM
    22/10/2003  09:10             4,647 DOSKEY.COM
    20/08/1997  02:20               496 DREADY.COM
    27/01/2004  22:42             1,570 ELTORITO.SYS
    30/07/2003  13:12             4,984 FIND.EXE
    08/04/2003  18:34             3,188 FINDCD.EXE
    30/07/2003  14:56           177,231 GDISK.EXE
    05/05/2001  22:22            10,351 HIMEM.SYS
    10/02/2003  11:07             1,835 INIFILE.COM
    01/07/2003  12:30           125,960 IO.SYS
    01/01/1999  01:01               282 KEYRATE.COM
    01/01/1999  01:01             2,419 killer.exe
    06/03/2004  18:45             1,514 LICENSE.TXT
    15/02/1999  01:53             8,270 MCD.EXE
    14/02/2004  15:34            20,412 MESSAGES.EXE
    19/07/2001  00:00            14,576 MSCDEX.EXE
    11/12/2003  17:02                99 MSDOS.SYS
    01/03/1999  02:50            34,335 PKUNZIP.EXE
    01/10/2003  17:18                52 RESET1.STP
    01/08/2003  10:54                93 RESET2.STP
    28/03/2004  14:33            35,273 SETUP.BAT
    28/03/2004  09:30            22,904 SETUP.INF
    10/03/2001  16:34               451 SHUTDOWN.COM
    13/02/2004  22:40             5,435 SUSCR.EXE
    17/02/1998  11:28             6,199 VIDE-CDD.SYS
    16/02/2008  17:32                64 W.BAT
    08/07/2003  10:23             8,868 WBAT.COM
    09/07/2001  11:10             1,992 XFIND.COM
    14/10/2001  08:16            11,627 XMSDSK.EXE
                  37 File(s)        638,373 bytes
     Directory of H:\DOS-on-USB\dos
    16/02/2008  19:13    <DIR>          .
    16/02/2008  19:13    <DIR>          ..
    12/01/2008  16:04    <DIR>          BOOT
    11/07/2001  15:59            12,288 DISKEM1X.BIN
    22/03/2004  21:21             1,252 DISKEMU.CMD
    16/02/2008  19:12    <DIR>          DOS71
    25/01/2004  13:40               401 SETUP.BAT
                   3 File(s)         13,941 bytes
     Directory of H:\DOS-on-USB\dos\BOOT
    12/01/2008  16:04    <DIR>          .
    12/01/2008  16:04    <DIR>          ..
    29/12/2001  19:51               512 DISKA.BIN
    11/06/2003  21:09               512 DISKC.BIN
    28/03/2004  14:44           737,280 DOS71INS.IMG
    23/06/2003  13:54             1,900 FAKEDISK.COM
                   4 File(s)        740,204 bytes
     Directory of H:\DOS-on-USB\dos\DOS71
    16/02/2008  19:12    <DIR>          .
    16/02/2008  19:12    <DIR>          ..
    16/02/2008  19:12    <DIR>          ADDONS
    12/08/2003  13:29                54 DISKVOL.TXT
    05/04/2004  13:28           807,701 DOS71_1S.PAK
    05/04/2004  13:16         1,433,337 DOS71_2S.PAK
                   3 File(s)      2,241,092 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS
    16/02/2008  19:12    <DIR>          AUTORUN
    16/02/2008  19:12    <DIR>          CHISYS
    16/02/2008  19:12    <DIR>          FILEMAN
    16/02/2008  19:12    <DIR>          MMEDIA
    16/02/2008  19:12    <DIR>          SYSTEM
                   0 File(s)              0 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\AUTORUN
    06/08/2003  13:10                58 AUTORUN.DAT
    06/08/2003  13:08                52 DISKVOL.TXT
    04/01/2004  13:26               272 DOS71ADD.ZIP
    06/08/2003  13:09               105 SETUP.DAT
                   4 File(s)            487 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\CHISYS
    16/02/2008  19:12    <DIR>          CCDOS
    21/02/2004  07:20               305 CDOS.ZIP
    05/08/2003  15:05                55 DISKVOL.TXT
    16/02/2008  19:12    <DIR>          PDOS95
    05/08/2003  15:06               103 SETUP.DAT
    16/02/2008  19:12    <DIR>          TW
                   3 File(s)            463 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\CHISYS\CCDOS
    12/08/2003  14:20           446,395 CCDOS.ZIP
    01/08/2003  08:17                68 DISKVOL.TXT
    05/08/2003  14:59               112 SETUP.DAT
                   3 File(s)        446,575 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\CHISYS\PDOS95
    01/08/2003  08:25                54 DISKVOL.TXT
    21/02/2004  07:07           532,716 PDOS.ZIP
    05/08/2003  15:04               101 SETUP.DAT
                   3 File(s)        532,871 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\CHISYS\TW
    31/07/2003  16:24                53 DISKVOL.TXT
    05/08/2003  15:02               102 SETUP.DAT
    05/08/2003  15:16           284,477 TW.ZIP
                   3 File(s)        284,632 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\FILEMAN
    06/08/2003  10:10                59 DISKVOL.TXT
    12/08/2003  14:24               197 FILEMAN.ZIP
    16/02/2008  19:12    <DIR>          GVFM
    06/08/2003  10:10               112 SETUP.DAT
    16/02/2008  19:12    <DIR>          VC
                   3 File(s)            368 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\FILEMAN\GVFM
    06/08/2003  10:27                74 DISKVOL.TXT
    06/08/2003  10:31           331,336 GVFM.ZIP
    06/08/2003  10:27               121 SETUP.DAT
                   3 File(s)        331,531 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\FILEMAN\VC
    06/08/2003  10:25                67 DISKVOL.TXT
    06/08/2003  10:25               114 SETUP.DAT
    06/08/2003  10:26            78,565 VC.ZIP
                   3 File(s)         78,746 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\MMEDIA
    06/08/2003  08:43                57 DISKVOL.TXT
    30/12/2003  10:28               307 MMPACK.ZIP
    06/08/2003  08:42               105 SETUP.DAT
    16/02/2008  19:12    <DIR>          SNDDRV
    16/02/2008  19:12    <DIR>          SNDPRG
                   3 File(s)            469 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\MMEDIA\SNDDRV
    16/02/2008  19:12    <DIR>          CMEDIA
    06/08/2003  08:50                55 DISKVOL.TXT
    16/02/2008  19:12    <DIR>          ESS
    16/02/2008  19:12    <DIR>          SBLIVE
    16/02/2008  19:12    <DIR>          SBPCI
    16/02/2008  19:12    <DIR>          SBPNP
    06/08/2003  08:50               103 SETUP.DAT
    21/12/2003  10:59             1,014 SNDDRV.ZIP
    16/02/2008  19:12    <DIR>          VIA
                   3 File(s)          1,172 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\MMEDIA\SNDDRV\CMEDIA
    06/08/2003  09:34            26,438 C3DMIX.COM
    06/08/2003  09:34            19,096 FIXEPIC.EXE
    06/08/2003  09:34             4,381 SETAUDIO.COM
                   3 File(s)         49,915 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\MMEDIA\SNDDRV\ESS
    19/07/1995  12:57            27,835 ESSCFG.EXE
                   1 File(s)         27,835 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\MMEDIA\SNDDRV\SBLIVE
    06/08/2003  09:50               181 CTSYN.INI
    06/08/2003  10:05            10,811 PSBEG.BIN
    06/08/2003  10:05               948 SBECFG.CFG
    06/08/2003  10:05            28,595 SBECFG.EXE
    06/08/2003  10:05           269,056 SBECORE.BIN
    06/08/2003  10:05           200,962 SBEGO.EXE
    06/08/2003  10:05             5,591 SBEINIT.COM
    06/08/2003  10:05            16,947 SBELOAD.EXE
    06/08/2003  10:05            59,788 SBEMIXER.EXE
    06/08/2003  10:05            34,187 SBESET.EXE
    06/08/2003  10:05             6,064 SBESET.TXT
                  11 File(s)        633,130 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\MMEDIA\SNDDRV\SBPCI
    08/06/2000  12:34           481,282 DOSTEST.ECW
    11/03/2002  09:57            33,599 SBCFG.EXE
    11/03/2002  09:57             3,677 SBINIT.COM
    11/03/2002  09:58            14,501 SBLOAD.EXE
    11/03/2002  09:59            67,059 SBPCI.BIN
    06/08/2003  09:46               672 SBPCI.INI
                   6 File(s)        600,790 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\MMEDIA\SNDDRV\SBPNP
    13/04/1997  20:08            87,508 CTCM.EXE
    13/07/2003  08:12                46 CTPNP.CFG
    07/04/1996  22:00            15,098 ENVMASTR.EXE
                   3 File(s)        102,652 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\MMEDIA\SNDDRV\VIA
    06/07/2003  07:12            39,233 VIAFMTSR.COM
    06/08/2003  11:52               443 VIAUDIO.COM
                   2 File(s)         39,676 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\MMEDIA\SNDPRG
    16/02/2008  19:12    <DIR>          CDP
    16/02/2008  19:12    <DIR>          MPXPLAY
    16/02/2008  19:12    <DIR>          QV
                   0 File(s)              0 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\MMEDIA\SNDPRG\CDP
    06/08/2003  09:37           220,358 CDP.ZIP
    06/08/2003  09:10                52 DISKVOL.TXT
    06/08/2003  09:10                94 SETUP.DAT
                   3 File(s)        220,504 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\MMEDIA\SNDPRG\MPXPLAY
    06/08/2003  09:15                61 DISKVOL.TXT
    06/08/2003  10:47           311,385 MPXPLAY.ZIP
    06/08/2003  09:15               111 SETUP.DAT
                   3 File(s)        311,557 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\MMEDIA\SNDPRG\QV
    06/08/2003  09:05                67 DISKVOL.TXT
    06/08/2003  09:36           279,368 QVPRO.ZIP
    06/08/2003  09:05               113 SETUP.DAT
                   3 File(s)        279,548 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\SYSTEM
    04/01/2004  13:10                59 DISKVOL.TXT
    16/02/2008  19:12    <DIR>          MSAV
    16/02/2008  19:12    <DIR>          MSBACKUP
    16/02/2008  19:12    <DIR>          NORTON
    04/01/2004  13:11               112 SETUP.DAT
    28/03/2004  06:09               210 SYSTEM.ZIP
                   3 File(s)            381 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\SYSTEM\MSAV
    28/03/2004  06:06                46 DISKVOL.TXT
    28/03/2004  09:56           204,423 MSAV.ZIP
    28/03/2004  06:59               113 SETUP.DAT
                   3 File(s)        204,582 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\SYSTEM\MSBACKUP
    28/03/2004  06:02                50 DISKVOL.TXT
    28/03/2004  11:43           576,327 MSBACKUP.ZIP
    28/03/2004  07:00               117 SETUP.DAT
                   3 File(s)        576,494 bytes
     Directory of H:\DOS-on-USB\dos\DOS71\ADDONS\SYSTEM\NORTON
    04/01/2004  13:13                58 DISKVOL.TXT
    28/03/2004  09:57         1,429,198 NORTON.ZIP
    04/01/2004  13:13               112 SETUP.DAT
                   3 File(s)      1,429,368 bytes
         Total Files Listed:
                 129 File(s)     10,233,080 bytes
                  89 Dir(s)   1,682,579,456 bytes free
    anyone know how any better package or tutorial for putting together a DOS onto USB?
    also, what other recovery program that might be useful? Memtest? Win 3.1?
  2. Zurechial
    Zurechial Elitist
    21 Mar 2007
    wyx087 likes this.
  3. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    Looks like you've been copying files to
    Root of the USB drive would be
    If you don't have any luck with that, try the HP USB format utility and point it to the files you've already downloaded when it asks for DOS files.
    It partitions and makes bootable the USB drive for you :)
    wyx087 likes this.
  4. herbs
    herbs Nobody but us chickens
    7 May 2001
    wyx087 likes this.
  5. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    wyx087 likes this.
