Networks What is the best way to control a PC remotely within the same house?
Discussion in 'Hardware' started by AcidJiles, 14 Aug 2013.
  1. AcidJiles
    AcidJiles Minimodder
    19 Jun 2006
    Looking to control my gaming pc from a spin bike in the garage and I was wondering if there is a way of doing this internally through the wireless or wired network without having the signal sent over the web like teamviewer etc would do? If I could directly patch in to the display, keyboard, mouse and sound from my PC so the connection is very low latency that would be ideal.
    Many thanks
  2. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    I like kainy
    Sent from my GT-I9505 using Tapatalk 2
    AcidJiles likes this.
  3. saspro
    saspro IT monkey
    23 Apr 2009
    VNC.
  4. faugusztin
    11 Aug 2008
  5. AcidJiles
    19 Jun 2006
    Anyway to use keyboard, mouse and monitor with a android tablet if I was to use this with that?
    Also does Kainy work internally within a network or does it have to leave to an external server?
    Thanks
  6. AcidJiles
    19 Jun 2006
    With some of those costs almost worth while to just build a cheaper gaming pc :). Will see if there is a cheaper way of doing this. Thanks for the info.
  7. faugusztin
    11 Aug 2008
    Well the USB is the easy (and nearly free considering the cost of the Pi) part as you can see, but getting the display and audio back is the hard (and expensive) part :).
  8. AcidJiles
    19 Jun 2006
    So I could combine things then. USB control through the PI and display and sound with VNC or Kainy. But I would need a windows pc for this, as the usb over ip wouldn't be compatible with an android device?
  9. faugusztin
    11 Aug 2008
    If you got VNC, you could just use your Pi as a VNC client directly too - but keep in mind that VNC performance is not usable for anything else but basic computer usage. Forget about gaming, or even youtube videos through VNC.
  10. AcidJiles
    19 Jun 2006
    Well I need something which I could use for gaming, not twitch shooter gaming but enough for strategy or 3rd person game. Is Kainy any better?
    Thanks
  11. faugusztin
    11 Aug 2008
  12. notmeagain
    notmeagain Minimodder
    29 Jan 2009
    What about HDMI over Wifi? and wireless USB hardware?
  13. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    I personally use splashtop, as it is compatible with ios and windows and it has an option to go for smooth vs speed, which is quite a useful feature. It also remembers your PCs so you don't have to mess around with the IP addresses and all that stuff :)
  14. theshadow2001
    3 May 2012
    Theres a remote protocol with windows 8 called remotefx it will probably do the job.
    Sent from my GT-P5113 using Tapatalk 4 Beta
  15. AcidJiles
    19 Jun 2006
    So this would work on my internal network? So I just need a simple pc to receive the stream? Thanks
  16. lysaer
    15 May 2010
    Kainy does work internally
  17. ultraelf
    ultraelf What's a Dremel?
    4 Jan 2010
  18. docodine
    docodine killed a guy once
    10 Feb 2007
    shocked nobody recommended RDP
    assuming you're on windows, RDP is the best possible option for this kind of thing
  19. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    Rdp doesn't allow you to run games from my previous experience a few years back
  20. law99
    law99 Custom User Title
    24 Sep 2009
    Yeah... You can't launch games in mstsc(rdp).
