Ha they admint its insanely big for an ITX case. ;P " You asked, we delivered. Prodigy M now features full compatibility with micro-ATX motherboards, all while maintaining the same compact dimensions as the original award-winning Prodigy. Featuring an all-new layout, Prodigy M is truly flexibility reimagined."
Ok a little bit of a necro i know but I just lost paitence waiting and went and bought one of these. I must say overal been a dream to build with. Generally oozes quality. My gripes so far If using an optical drive both of the top 120mm fans are unusable. SSD Vertical mounting arm doesnt allow fat SSD's in there The side panel with power and usb is the side you would need to remove if you want to open up and add something, so thats means every time you need to disconnect all the headers... Other than that, great case, and possibly the tidest build I have done in a long time.
