Hi I need help for building a gaming PC preferably under the budget of £600, I'm having a hard time deciding on which parts to buy without going over the budget much, but I seem to go just out of my reach if I don't want to lose major jumps in performance, currently, I've came up with something like this: CPU: Core i5 4690k (£169.99) Cooler: Cooler Master Seidon 120V (£34.98) (Can't find a cheap case that would fit the 212 EVO, if you guys know a case for under £40 please recommend) Motherboard: Gigabyte Z97P-D3 (£56) or Z97-D3H (£68) RAM: 16GB Crucial 1600MHZ CL9 (£50.99) (Already brought from Amazon sales) SSD: 250GB 850 EVO (£42, buying a unused one off a friend) HDD: 2TB 7200rpm Hitachi (£49) GPU: XFX 4GB R9 380 (£160) PSU: Corsair CX500 (£40) Case: Corsair 100R (£39) Total:£641.96 or £653.96 As you can see I can only have £630 ish and I need this PC ASAP as my current laptop broke, is there anywhere I can cut down the costs here to that amount or replace my parts with similar performing but cheaper ones? Thanks
Easiest way to cut down would be hold off on buying the SSD and just install windows on the HDD for a few months
Get a cheaper 8 Gb set of ram. 8 is fine and you can add more later if you need. Combining that with a cheaper 1tb drive would probably bring you below 600.
