HTPC WIRELESS HEADPHONES ANY SUGGESTIONS
Discussion in 'Hardware' started by dave454, 4 Oct 2010.
  1. dave454
    dave454 What's a Dremel?
    4 Oct 2010
    hello im new to the forum and was just wondering if anyone uses wireless headphones with a htpc setup i already have a set of wireless headphones (£30 and 7 years old now) but i am looking to upgrade them so i can have it as loud as i want without upsetting neighbours family etc. was looking at aroung the 80-130 pound budget for them, if anyone has any suggestions for me that would be good. cheers
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Heres a suggestion. Don't make a thread title in caps.
  3. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    Might wanna take a look at Sennheiser RS-140.
  4. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Ph4ZeD - Too fast!
    Sennheiser RS Series. Pick your price and buy!
  5. dave454
    4 Oct 2010
    ph4zed thanks for that your help is really appreciated, cheers guys ill check the sennheisers out.
  6. smc8788
    smc8788 Multimodder
    23 Apr 2009
    I wouldn't, they're getting on a bit now and the wireless technology is outdated. The newer RS 170's will be a lot better (I own a pair myself, I like them a lot).
  7. dave454
    4 Oct 2010
    they look good what it is the sound like bass etc and is there any signal noise atall?
  8. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Since they use a digital wireless technology instead of radio frequencies there is zero interference at all, even if I move away from the transmitter. Bass is pretty good as is, and they have a bass boost function as well as a surround function, which is most useful in games.
  9. dave454
    4 Oct 2010
    cheers mate i have been looking at the sennheiser and they do look the part so they look like a gud purchase, there isnt many alternatives though ive been finding it hard to find any on the net apart from the sennheiser's
  10. SlowMotionSuicide
    16 May 2009
    Yeah, RS-170 was first to spring to my mind too, but quick search showed they retail around 215€ around here atm so I thought they're somewhat out of the given budget range of 80-130£. Not sure if you guys can buy audio gear cheaper though.
    Edit:/ just checked out the newegg link, very nice price. Finland is stupidly expensive country:(
    TBH, I'd steer clear of any sort of wireless headphones, but that's just me. AKG K601 are the cans of my choice:rock:
