Scratch Build – In Progress R-kaid-6 > (UPDATE 07.05.12 Additional wooden gamepad)
Discussion in 'Project Logs' started by quizz_kid, 12 Sep 2011.
  1. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Two of the final pictures, check page 6 for more of them
    This is my second modding attemt and I´m here to recycle. I´ll be turning my very old computer into a kind of arcade console, emulating classics from the NES, SNES, SEGA, NEO GEO and many more. I´ll be using the arcade interface program Maximus Arcade for autoboot. I want to keep this artifact very simple, with sharp edges and small stylistic features, all covered in hardwood.. If you´ve seen my previous mod sputnik 0667 you´ll be familiar with the color concept: walnut, brass and matte black. I just can´t get enough of that combo! I´m going to use walnut lumber and some veneer on MDF.
    My old computer:
    ASUS M2R-FVM
    AMD Athlon 64
    Geforce Winfast px7600 gt
    DDR 512 mb
    HDD 160 GB
    I´m not gonna use the DVD due to the lack of space.
    Well, let´s get started...
    And here, some dust and some RAW HEEEEE-MAN POWER!!!:
    Look at this beauty! I love it... and so did the worms too once...
    Okay, so I´ve just cut the lumber, some 18mm MDF and glued them together in six side pieces.
    Tomorrow, it´s veneering time!
  2. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Another retro looking, cool idea build starting. :thumb:
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    Subbed I'd like to see how this turns out, nice idea :).
  4. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thnx man!
    Well me too... Thank you
  5. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Veneering's done and done!
    Cutting those angles
    The front. Those smaller holes were not suppose to look like nostrils, but they DOOO!:sigh:
    Main push button
    These are the joystick connectors. I wanted them to be unique in some way and figured standard USB wouln´t do it. So I picked these DIN 4-pin connectors which I found kinda retro looking
    The front fans, or the "eyes". Never though I was gonna use led fans, but why not? Those eyes will burn in the night...
    The backside. I´m going to use the fan from my PSU for intake on the back.
    Originally, I wanted to use a S-video to RCA-adapter for the retro feeling, but it turn out that wasn´t gonna work. When I plugged it to my TV, all I got was a bad b&w picture. Left with a few choices, I chose the VGA connector. So now I have to use a seperate cable for sound :miffed:
  6. LeandroJVarini
    LeandroJVarini Mod is my life!
    25 Dec 2007
    I love the project wood! following
  7. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Today I extended the PSU fan...
    and put all the side pieces together!
    Fronts
    Backs
    Bottom piece. nothing fancy, also 18mm MDF. I think this console´s gonna be quite heavy
    Close up
    Glue and let dry...
    Finished shell!! The holes near the top are for dowels carrying the upcoming roof piece
    I also made a mount for the HDD...
    That´s it for today! yay!! :lol:
  8. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Subbed - neat idea.
  9. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Today I began working on the foot. It´s almost identical to the one I made for Sputnik 0667.
    I also made the VGA cables. That´s a lot of soldering for two sockets...
  10. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    thank you
  11. craig - toyoracer
    1 Mar 2011
    Solid work, coming together nicely :)
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    Verrry nice :clap:.
  13. longweight
    7 May 2011
    Really nice job mate!
  14. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    thank you friends!
  15. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Started on those joysticks today. pieces cutted and glued...
    The making of customized usb cables, where I combine 4-pin DIN connectors with standard telephone coil cords. Gives it a nice touch I think.
    Turned out it was a bit tricky soldering the small fragile copper wires into to the pins...
    They would just break, break and break
    ... so I made these "briges", and heated directly on the plastic instead. It worked much better.
    kinda creepy looking thing
    finished and works just fine!
  16. -Jv-
    -Jv- What's a Dremel?
    29 Mar 2011
    That's some pretty impressive work. I like the Sputnik 0667 alot so I have high hopes for this !
  17. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    Awesome! Makes me want to mod all me retro consoles into one big box. (I wont of course, that would be sacrilege)
    Will enjoy watching this grow :)
  18. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanx man. I too have high hopes, but if Sputnik is the meanest monster broiler from "Licence to grill", this project is more like a standard toaster. This one is going to end up more than fine, I just put a lot more heart and time into the Sputnik-mod.
    Thank you. I know all about bad sacrilege
  19. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    The joysticks are getting top sides
    cutted for a perfect fit
    glued, dried and off to the sandpapers
    support pieces
    veneer cutting
    glue, maybe a bit too much, I don´t know :confused:
    some support for the pressure
    pressure over night. C Yall 2morrow :D
  20. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    continued on the joysticks today...
    veneer for the bottom pieces
    here they are, dried and cut.
    controllers
    a bit of sandpapering and ready for the drill. customized layout printed out on paper. I just marked the holes with a pricker. No ruler reeded...
    I then used a 30mm bit for the standard 6 push buttons and a 25mm for the rest.
    The buttons are being shipped from japan as we speak. They´re not cheap, but it´s worth it!
    I know I said I wanted sharp edges, but decided to use a milling machine anyway. I made these tiny 45 angles just incase a decide to do some hardcore gaming :naughty:
    Almost done now
    I put one more support piece inside. I don´t trust 6mm MDF
    bottom pieces on. brass screws coming up
