Guide Make your own USB LCD controller!
Discussion in 'Modding' started by ch424, 23 Jun 2006.
  1. ch424
    ch424 Design Warrior
    26 May 2004
    Hi everybody
    Ages and ages ago, I posted this and many people said they'd like a guide. So here it is!
    This is a guide for making an LCD that connects to your computer using USB, primarily intended to be external. You can see mine here. To make the board smaller, it doesn't have the GPOs.
    This thread should also be used for suggestions on how to improve the circuit, add new features, and fix bugs in the firmware.
    Schematic and layout
    First of all, the schematic.
    The PCB layout in colour.
    And a 300dpi printable version.
    Component list:
    R1; R8; R9; R10: 10k
    R2; R7: 4k7
    C1; C2: 22pF
    C3; C5: 100nF
    C4: 220nF
    C6: 100uF
    Q1; Q6: BC184L
    RV2: 4k7 preset
    LCD1: HD44780/KS0066U compatible
    X1: 4MHz
    T5: USB B (bought from Farnell)
    J2: ALPS 11mm rotary encoder (from RS, part 263-2930)
    BUZ1: miniature buzzer
    U1: PIC18F2550 DIP28
    Note that I've used a transistor for the buzzer, so you can connect someting else there instead... mod on!
    The connection to the rotary encoder works like this: (diagram)
    Pin 2 on encoder goes to pin 1 on J2
    Pin 3 on encoder goes to pin 2 on J2
    Pin 5 on encoder goes to pin 3 on J2
    Pins 1 and 4 on encoder go to pin 4 on J2
    Firmware
    Here.
    Installing in Windows
    XP/2000: Download this to your desktop and tell Windows to use that as a driver when it asks.
    Vista 64-bit: see scorpia's post
    I think Vista 32-bit works with the XP/2000 method, I'm not sure though.
    This is the required programmer config (assuming 4MHz crystal). The USB voltage regulator is critical, as the PIC won't even try to start up without it.
    Supported commands:
    Position: 254 71 [col] [row]
    Home: 254 72
    Underline on: 254 74
    Underline off: 254 75
    Blink on: 254 83
    Blink off: 254 84
    Define custom: 254 78 [c] [8Bytes]
    Clear display: 254 88
    Backlight on: 254 66 [mins] (mins is just discarded)
    Backlight off: 254 70
    Backlight brightness: 254 152 [value]
    GPO off: 254 86 [1-4]
    GPO on: 254 87 [1-4]
    Set GPO PWM: 254 102 [1-4] [0-100] (works as a percentage)
    Buzzer off: 254 86 5
    Buzzer on: 254 87 5
    Computer software
    This will work with LCDSmarite, if you set it to a Matrix Orbital serial LCD.
    And finally... mine in action:
    Any questions, feel free to ask!
    ch424
    Snakko, thaimin and cpemma like this.
  2. DougEdey
    5 Jul 2005
    Is this the one that works with 4x20 displays?
  3. ch424
    26 May 2004
    Anything up to 20x4, as long as they're HD44780 or KS0066U compliant. KS0066FF00 is incompatible.
    It doesn't work with 40x4 displays.
    ch424
  4. DougEdey
    5 Jul 2005
    Excellent!
    Now I'll have to breadboard it since i have no etching tools.
    Cheers ch424
  5. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    This looks really handy but I really don't have the skills... but if some would like to make one extra I could suitably reimburse them for their time and effort :thumb:
  6. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    Pr0! You didn't route the datalines through the powersupplies.
    ;) :thumb:
  7. Vocko
    Vocko What's a Dremel?
    28 May 2004
    I have a HD44780 unit that connects to parallel port. Is it possible to mod it so I can connect it to USB ?
    thnx
  8. newbiedude
    newbiedude What's a Dremel?
    24 Jun 2006
    what was the total cost of the parts that you got?
  9. ch424
    26 May 2004
    Yes, that's precicely what this circuit does - and more!
    As for total cost... £10 plus the cost of the PCB (£3?) and an LCD (£16-£35?)
    ch424
  10. DougEdey
    5 Jul 2005
    YEt another question for you CH424, can this be adapted for a T6963C LCD? Not a NxM display though, has 20pins...
  11. Valo
    Valo Minimodder
    11 Aug 2004
    hmm... what does it exactly do? do I need programmer to make that thing work?
  12. ch424
    26 May 2004
    Doug, no it can't, sorry.
    Valo, have a look at the FAQ: http://forums.bit-tech.net/showthread.php?p=490773
    This basically connects to your computer, and can show system info, temperatures, time/date, track/album/artist name from itunes/media player/winamp, control winamp, say when you have new emails, show RSS feeds - and more!
    ch424
  13. Vocko
    28 May 2004
    Rotary knob and the buzzer are used for what ?
  14. ch424
    26 May 2004
    Navigating menus, changing tracks, controling volume etc. You can set the buzzer to buzz under certain conditions: e.g. when you get an email or if your temps get too high.
    ch424
  15. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    Very nice mod guide, nice pictures and its clearly explained I might even give it a try, once I get a little funds for the parts of course....
  16. ch424
    26 May 2004
    Not really free: the price is that it takes 6 weeks for delivery. If you just pay £4 you can get one next day!
    ch424
  17. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
  18. ch424
    26 May 2004
    Wow, that's brilliant! Thanks!
    ch424
  19. H2O-G33K
    H2O-G33K What's a Dremel?
    25 Jan 2003
    Excellent. I'd been thinking about having a crack at implementing what you've done for a while now. Good effort - I'll give it a go when I get back from my holidays :)
  20. One~Zero
    One~Zero What's a Dremel?
    9 Sep 2004
    Excellent work ch424!! :thumb:
    Do you know if they make that PIC in a SMD package? I'd like to make it as small as possible....but then again, how could I upload the hex to a SMD PIC....? :eyebrow:
    This is just what I was looking for to try out on my 4x20 PLED :rock:
