Case Mod - In Progress Spray painted my Notebook (Alienware Superman Theme)
Discussion in 'Project Logs' started by janavar, 15 Mar 2009.
  1. janavar
    janavar What's a Dremel?
    15 Mar 2009
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I used spray paint for a case paint project of mine
    it didn't turn out as good as yours (there was a some dust, bubbles.... in the paint) but you can't beat a $4.07 paint job
  3. McGrego
    McGrego What's a Dremel?
    21 Jun 2008
    looks really nice! try some car war or polishing compound to give it some extra shine!!
  4. janavar
    15 Mar 2009
    Thanks,
    after 1-2 months get some good polish and some nice turtle wax and it will be SHINY!
  5. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    what is the superman logo made out of, is it just paper?
    I have nearly finished painting the same panel on my laptop, i had to find a replacement because my laptop got damaged. And i took the chance to to paint it!
    I have been looking into stencils, but i want a super crisp edges. so i might just get some vinyl cut.
  6. luis_pedro_Sato
    luis_pedro_Sato Minimodder
    29 Nov 2004
    Looks great.
    Congrats
  7. janavar
    15 Mar 2009
    yes, it is just superman logo sticker , i cut it edges. and after i painted 3 coats varnish paint (gloss)
    are you view to video ? (more pictures)
    Thanks Pedro
  8. janavar
    15 Mar 2009
  9. janavar
    15 Mar 2009
    updated
