Peripherals Budget Gaming Mouse
Discussion in 'Hardware' started by Harddiskdriver1, 3 Oct 2010.
  1. Harddiskdriver1
    Harddiskdriver1 What's a Dremel?
    22 Aug 2009
    Okay, so I'm fed up of the microsoft ball mouse we have with its sticky scroll wheel and dodgey tracking. It must be something like 8 years old now:D. I've been looking at gaming mice in the range of 30 to 40 pounds. I don't need a supermouse, just something that tracks accurately, scrolls reliably and (if possible) has 2 side buttons. Can anyone recommend anything? I'm hoping for the word 'Razer' to be in one of your replies xD.
  2. Jipa
    5 Feb 2004
    MX518.
  3. MoRbEin
    MoRbEin I know what a Dremel is!
    30 Sep 2010
    Razer Deathadder Re-Spawn Mouse
    Cant fault this one, never had a problem with it, very comfortable if you palm grip, the side buttons are just in the right place for my thumbs. and compared to your 'Ball-based-mouse', this uses infrared sensors! =D
  4. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    as above
  5. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    ^What he said.
    Or this.
  6. Harddiskdriver1
    22 Aug 2009
    yeah, ive been looking at both of these. the deathadder looks the better choice to me, but there is a big price difference
  7. Shadowed_fury
    21 Nov 2003
    I tried a g500 over my deathadder for a fortnight. Wasn't sure if I liked it, so went back to the Deathadder and mmm so much nicer.
    Thankfully found a fast buyer for g500 so nothing wasted there :D
  8. MoRbEin
    30 Sep 2010
    had a g500 back then, its a mouse you should consider as well. I liked it but not as much as the Deathadder. Thumb rests aint my thing.
