One of my machines is having problems sending results, Ive even taken off the firewall and antivirus trying to work through problems, all my other machines are fine its just this one with the GPU Systray clients that are being iffy heres a FAHMON copy paste [19:41:16] Folding@home Core Shutdown: FINISHED_UNIT [19:41:20] CoreStatus = 64 (100) [19:41:20] Sending work to server [19:41:20] Project: 5759 (Run 2, Clone 491, Gen 23) [19:41:20] + Attempting to send results [June 16 19:41:20 UTC] [19:41:23] + Results successfully sent [19:41:23] Thank you for your contribution to Folding@Home. [19:41:23] + Number of Units Completed: 169 [19:41:27] Project: 5905 (Run 12, Clone 785, Gen 6) [19:41:27] + Attempting to send results [June 16 19:41:27 UTC] [19:41:48] - Couldn't send HTTP request to server [19:41:48] + Could not connect to Work Server (results) [19:41:48] (171.64.122.70:8080) [19:41:48] + Retrying using alternative port [19:42:09] - Couldn't send HTTP request to server [19:42:09] + Could not connect to Work Server (results) [19:42:09] (171.64.122.70:80) [19:42:09] - Error: Could not transmit unit 05 (completed June 15) to work server. [19:42:09] + Attempting to send results [June 16 19:42:09 UTC] [19:42:30] - Couldn't send HTTP request to server [19:42:30] + Could not connect to Work Server (results) [19:42:30] (171.65.103.100:8080) [19:42:30] + Retrying using alternative port [19:42:51] - Couldn't send HTTP request to server [19:42:51] + Could not connect to Work Server (results) [19:42:51] (171.65.103.100:80) [19:42:51] Could not transmit unit 05 to Collection server; keeping in queue. [19:42:51] - Preparing to get new work unit... [19:42:51] + Attempting to get work packet [19:42:51] - Connecting to assignment server [19:42:52] - Successful: assigned to (171.64.65.106). [19:42:52] + News From Folding@Home: Welcome to Folding@Home [19:42:52] Loaded queue successfully. [19:42:58] Project: 5905 (Run 12, Clone 785, Gen 6) [19:42:58] + Attempting to send results [June 16 19:42:58 UTC] [19:43:19] - Couldn't send HTTP request to server [19:43:19] + Could not connect to Work Server (results) [19:43:19] (171.64.122.70:8080) [19:43:19] + Retrying using alternative port [19:43:40] - Couldn't send HTTP request to server [19:43:40] + Could not connect to Work Server (results) [19:43:40] (171.64.122.70:80) [19:43:40] - Error: Could not transmit unit 05 (completed June 15) to work server. [19:43:40] + Attempting to send results [June 16 19:43:40 UTC] [19:44:01] - Couldn't send HTTP request to server [19:44:01] + Could not connect to Work Server (results) [19:44:01] (171.65.103.100:8080) [19:44:01] + Retrying using alternative port [19:44:22] - Couldn't send HTTP request to server [19:44:22] + Could not connect to Work Server (results) [19:44:22] (171.65.103.100:80) [19:44:22] Could not transmit unit 05 to Collection server; keeping in queue. [19:44:22] + Closed connections [19:44:22] [19:44:22] + Processing work unit [19:44:22] Core required: FahCore_11.exe [19:44:22] Core found. [19:44:22] Working on queue slot 06 [June 16 19:44:22 UTC] [19:44:22] + Working ... [19:44:22] [19:44:22] *------------------------------* [19:44:22] Folding@Home GPU Core - Beta [19:44:22] Version 1.19 (Mon Nov 3 09:34:13 PST 2008) [19:44:22] [19:44:22] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86 [19:44:22] Build host: amoeba [19:44:22] Board Type: Nvidia [19:44:22] Core : [19:44:22] Preparing to commence simulation [19:44:22] - Looking at optimizations... [19:44:22] - Created dyn [19:44:22] - Files status OK [19:44:22] - Expanded 70183 -> 360060 (decompressed 513.0 percent) [19:44:22] Called DecompressByteArray: compressed_data_size=70183 data_size=360060, decompressed_data_size=360060 diff=0 [19:44:22] - Digital signature verified [19:44:22] [19:44:22] Project: 5764 (Run 12, Clone 465, Gen 12) [19:44:22] [19:44:22] Assembly optimizations on if available. [19:44:22] Entering M.D. [19:44:28] Working on Protein [19:44:30] Client config found, loading data. [19:44:30] Starting GUI Server [19:45:51] Completed 1%
171.65.103.100 There are problems with this server at Stanford. No need to worry, once it's up and running again your results should go through (unless you fill your 10 queue places, then work will stop)
