News Samsung launches Series 9 Quad HD IPS PLS monitor
Discussion in 'Article Discussion' started by brumgrunt, 27 Jun 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    Needs moah acronyms :D
  3. coolius
    coolius What's a Dremel?
    29 Jul 2007
    isn't Quad HD generally regarded as 4*1920x1080 rather than just 4*1280x720 ?
  4. Gareth Halfacree
    4 Dec 2007
    No - officially, that's QFHD (Quad Full High Definition.) EDIT: Although 'Quad HD' is more properly termed WQHD - Wide Quad High Definition.
  5. Jehla
    Jehla Minimodder
    8 Jan 2010
    Any chance of a review if it gets released over here? This is maybe the prettiest pc monitor about.
  6. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    Bawww.
    Came in here expecting a 4k display... I am dissapoint.
  7. 3lusive
    3lusive Minimodder
    5 Feb 2011
    I think you should have just put 1440p, or simply 2560x1440, instead of Quad HD, because with the advent of 4K screens around the corner people are already using the term Quad HD (as in 4x 1080p and not 4x 720p) to refer to 4K displays. I'v seen it numerous times across the net. Such as here and here.
    I know you're technically correct, but it just helps un-muddy the water.
  8. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    "Samsung has opted not to include an HDMI cable with the display."
    I thought HDMI only supported 1920x1080 anyway.
  9. GeorgeStorm
    16 Dec 2008
    Wow that's pricey.
    Must admit, when I saw Quad HD I was expecting more than 1440p....
    Not sure why anyone would choose this over something like the U2711?
  10. Gareth Halfacree
    4 Dec 2007
    Nup - HDMI 1.4 is quite happy with 3840x2160 (which, interestingly, Wikipedia calls Quad HD, despite calling it QFHD elsewhere.)
  11. Nikumba
    Nikumba Minimodder
    29 Aug 2001
    Would rather stick with my Dell 27" IPS as it looks a lot better, not glossy frame. I really can not understand why monitor makers feel the need to make everything glossy.
    Kimbie
  12. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Is PLS any better than IPS?
    I was thinking of getting a 2nd U2410, put if PLS is better than IPS, I'll have to look at that route (*le wait for goodbytes to write a lengthy response explaining EVERYTHING)
  13. Krikkit
    21 Jan 2003
    Mmm... That's nice! Not sure why it's only got USB2 hub though, surely USB3 would be reasonable? It's not like the spec is new, and it's only a hub circuit squashed into a monitor casing.
  14. 3lusive
    3lusive Minimodder
    5 Feb 2011
    Just going off what I remember, it is extremely similar to IPS displays. However, in the displays which currently use PLS, they have better AG coating than found in typical IPS ones, such as the Dell Ultrasharps, as it is not as grainy or sparkly. This may be why they appear to have better contrast and black depth too.
    I know Linus believes the PLS monitor he tried had the best viewing angles he'd ever seen.
  15. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    The bit about being able to play video and sound from one's phone while also charging it sounds pretty nifty, I have to say. Other than that I was expecting a higher resolution like GeorgeStorm.
  16. jrs77
    jrs77 Modder
    17 Feb 2006
    Samsung SyncMaster S27A850D looks better imho with the thinner frame and square foot-stand. Also all black!
    Allready available and cheaper using the same panel.
  17. azrael-
    azrael- I'm special...
    18 May 2008
    There's really nothing tangible to recommend this monitor over the Dell U2711. That says something, doesn't it...
  18. fdbh96
    29 May 2011
    I suppose no one other than Samsung know what the image quality is like yet.
  19. Gareth Halfacree
    4 Dec 2007
    Hah! That's what you get when you spell out Light-Emitting Diode (LED,) then think "nah, everyone knows what LED stands for."
  20. streetuk
    streetuk What's a Dremel?
    3 Jul 2009
    Go walk into an Apple store tomorrow and compare the matte Macbook Pro's with a glossy Macbook Pro. Once you do you will understand why monitor makers feel the need to make everything glossy.
Tags: Add Tags
