Memory Laptop RAM 200 or 204-pin SODIMM?
Discussion in 'Hardware' started by Timmy_the_tortoise, 31 Jul 2011.
  1. Timmy_the_tortoise
    Timmy_the_tortoise International Man of Awesome
    28 Feb 2008
    Hi,
    I want to upgrade my Laptop RAM, and I have never done a Laptop RAM upgrade before so I don't know much about SODIMMs... I know I want 533MHz DDR2, but have seen 200 and 204 pin sticks available.. is there a distinct difference which will make it easy to tell which type I want?
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    A good idea is to use crucials memory advisor, that will show you exactly what type you need. Once you know the exact type you need you can then shop around if crucial aren't the cheapest etc
    Crucial memory advisor
  3. Timmy_the_tortoise
    28 Feb 2008
    Ran the test... Thanks. Apparently I can't use DIMMs bigger than 1GB..
    Also, 200-pin = DDR/DDR2
    204-pin = DDR3..
    Bought a Corsair 2GB Kit.
    Thanks for the help!
