Starting another endeavor. This time will be a mini PC, or so mini, but mini. The hardware will be used: * Case Aerocool Dead Silence Cube Black / White * Processor Core I7 4790K * Motherboard Gigabyte Z97MX-Gaming 5 * Ram 16GB G.Skill Sniper 1600 (probably in water) * 250gb SSD Samsung 840 EVO * 3TB Sata 3 HD * Source OCZ ZX1250w *Video Card EVGA GTX Titan SC + EVGA Hydro Copper Waterblock * Fans CM JetFlo white LED Water cooler * Radiator Swiftech MCR220-XP * Radiator XSPC EX120 * CPU Waterblock EK Supremacy Clean Gold CSQ * Pump Koolance PMP 450S + Top Alphacool * Fittings Primochill Revolver for acrylic tube * Reservoir mini 90mm * 12.7mm Primochill Tubing ------------------------------------------------------ This project is to assemble a PC with relatively high performance without spending too much and keeping the minimum of space. I will use blue and white cables (extenders). Case will be done in acrylic window of 2 sides, front with a custom laser cutting. I intend to use acrylic tubes, since the internal space permits use. The fittings are white. Fans will be with the white LED. ------------------------------------------------------ Some photos of the parts as soon as they reached all I post actual photos.
Hello and welcome to the forums I have moved your thread from Project Logs as you need to have pictures of work in progress in order to have a project log. Regards GK
