Other Encrypt USB Flash Drive
Discussion in 'Software' started by longweight, 4 Dec 2013.
  1. longweight
    7 May 2011
    Hi all, I'd like to encrypt the USB drive that I use for my university work, not to a really high level but just to stop people copying my files in the labs etc. Can anyone recommend anything? Preferably free but I don't mind paying a bit for something that works really well. Oh and it is a 16Gb drive.
  2. littlepuppi
    littlepuppi Currently playing MWO and loving it
    26 Apr 2009
    Can you afford an ironkey?
  3. longweight
    7 May 2011
    Jesus they are expensive!
  4. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
  5. theshadow2001
    3 May 2012
    Use true crypt.
    Put a a true-crypt file on the usb key which takes up most of the space. Leave a little bit so you can have a portable version of true crypt. Plug in the key, run true-crypt, mount the file put in your password bobs your uncle.
    This may work better if you partition the drive. A small partition for true-crypt portable and an encrypted partition for your data.
    Its all free.
  6. longweight
    7 May 2011
  7. longweight
    7 May 2011
    Can you access the drive without administrator rights?
  8. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Can't think of any software solutions that don't require admin to function properly (or at all). I would assume you won't have such privilege on lab computers?
  9. longweight
    7 May 2011
    Sadly not:(
  10. theshadow2001
    3 May 2012
    I'm not sure is the short answer. The portable edition triggers UAC when you run it. But you can throw it on a usb key and try to run it the next time you are in college (I'm assuming you are using university supplied computers) Just try and run the portable edition, you wouldn't have to go through the hassle of actually encrypting partitioning etc. to test if it runs or not.
    Edit
    http://www.truecrypt.org/docs/non-admin-users
    What about doing something like creating a hidden folder so people won't know its there?
  11. longweight
    7 May 2011
    Ok I will have a go, thank you :)
  12. IvanIvanovich
    31 Aug 2008
    Needs a driver installed to access virtual disk device... which needs admin at least one time.
    There are a bunch of other hardware based encryption besides iron key... I think imation secure+ are probably the cheapest.
  13. longweight
    7 May 2011
  14. IvanIvanovich
    31 Aug 2008
    Seems about how much the cheaper imation I mentioned last time are here with good old $=£ conversion.
  15. longweight
    7 May 2011
    It does but I couldn't find that one from a decent source in the UK.
    Thanks for the help!
  16. IvanIvanovich
    31 Aug 2008
    Hehe... I could have mailed you one from USA... even more saving buying things in devalued dollars.
  17. Buzzons
    Buzzons Minimodder
    21 Jul 2005
  18. longweight
    7 May 2011
    I only have a home license.
  19. Buzzons
    Buzzons Minimodder
    21 Jul 2005
  20. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    whats wrong with bitlocker to go?
