How do I write a SQL query involving a time stamp? QUOTE_ID is a character string CREATE_DTG is a date time type RETENTION_LEAD_TRACK is a table This sql statement cmf.CommandText = "SELECT QUOTE_ID FROM RETENTION_LEAD_TRACK where CREATE_DTG > '2016 - 04 - 25 18:18:15.2891'" throws this error {"Conversion failed when converting date and/or time from character string."}
Clearly MS SQL Server based on error. So either use 'YYYY-MM-DDTHH:MM:SS' format, or use the CONVERT function in form of convert(datetime,'DATESTRING',FORMAT) : https://msdn.microsoft.com/en-us/library/ms187928.aspx
I think it all depends on where your actual date is coming from... But if push comes to shove, use CAST over CONVERT because it is ANSI compliant and preserves precision: Code: ...WHERE CREATE_DTG > CAST('2016 - 04 - 25 18:18:15.2891' AS DateTime)
