Not those ones, you perverts! I need a couple of replacements for a bike frame, but i'm having trouble finding a like-for-like for this: It's a M10 flange nut with an OD of 25mm. Everything I can see tops out at 22mm. Preferably the replacements will be aluminum like the OEM ones, but to be honest steel or even titanium will do. Colour isn't important, as long as it isn't something completely obscure that can't be matched up with the corresponding bolt... I know I can use a standard nut and washer, but again it's difficult to find a 25mm OD washer that isn't a butt fugly standard penny washer - considering these are for the main pivot bearings I would like them to look fairly professional. If anyone can find a swish drilled/domed/race spec 25mm OD sample that could work too. Go team!
