Scratch Build – In Progress [Project] Acrylic tube " Fire and Ice " 25/08/2012 - Finishing all
Discussion in 'Project Logs' started by cienik, 25 Aug 2012.
  1. cienik
    cienik What's a Dremel?
    25 Aug 2012
    Hello Master, Here noob want to start a simple project with tube shape with Fire and ice theme.
    I am from Indonesia and here i can't found any modding stuff as easier as other country so i just start with easy build.
    Ok start with the tools i have ( i just have simple tools so i will try my best to use it )
    - Drill
    - Acrylic cutter
    - U-saw
    - Ruller
    - pencil
    - file + sand paper
    - solder
    Other stuff :
    - Flexible led to create the theme
    Here i have finish design what i need to create acrylic tube .
    i try to make it as compact as possible and my plan is all part will connect using small iron elbow so it must be strong enough to hold all part.
    Next step : buying acrylic ( should be ready tomorrow ) = Done
    picture of acrylic
    Big note : i don't have any big machine like laser , cnc , electric saw , etc expensive machine so i hope my log can give all noob spirit to start their first mod even they don't have machine above. mod is start with spirit and end with satisfy .
    Next step is cut the acrylic based from the design ( BIG JOB ).
    - i will use only acrylic cutter with ruler to cut the acrylic
    - will use drill with bit to make a small hole
    - will use drill with adjustable blade to make big hole for fan
    - will use sand paper to smooth the edge ( acrylic ) then langsol ( at indonesia ) it is use to polish an aluminium .
  2. Nexxo
    23 Oct 2001
    Project logs rule #2... Moved to Modding for now.
  3. cienik
    25 Aug 2012
    cutting
    here i have start cut all the acrylic based on the design i have made before
    nb : cutting is using acrylic / plastic cutter. hole is made using drill .
  4. cienik
    25 Aug 2012
    create hole and start connect all part
    after all part already cut then i start to connect all part using bolt and small elbow... here is the pictures
    I am using 3 dvdrw , thermaltake fan control , card reader and on off drive.
  5. Nexxo
    23 Oct 2001
    Moved to Project Logs. :thumb:
  6. Mcbeer
    Mcbeer What's a Dremel?
    30 Apr 2012
    This is gonna be interresting :)
  7. cienik
    25 Aug 2012
    half part done - put it on
    Half part done - put the part on the table.
    in the dark
    Half project already done . and today will continue by adding fan to the both left and right side.
  8. cienik
    25 Aug 2012
    add top left and top right side panel.
    with 2 color fan , blue and red ( ice and fire ) for matching the theme.
    "apolish like fan ... handmade....lol.... "
  9. cienik
    25 Aug 2012
    finishing
    Finishing :
    when light on
    when light off
