Project: Silent Server (Mini ITX) - Finished!
Discussion in 'Project Logs' started by solar, 30 Jul 2005.
  1. solar
    solar What's a Dremel?
    6 Mar 2004
    Last summer I built myself a Mini ITX Linux workstation - the Blue Penguin. I used it for a few months and it was great, but it was always a little slow for really comfortable, everyday use - because of the slow 2.5" hard disk, I think. Eventually I found a Linux distro (Yoper) which works very well on my laptop, so the Blue Penguin fell out of use.
    Recently I've been thinking about building myself a file server for my network, and so I decided to use some of the bits from the Blue Penguin to do it.
    The most important thing with this computer is for it to be silent or very quiet, because it'll be running 24/7 in my bedroom. The ideal mobo for this would be one of the fanless Mini-ITX boards, such as the Epia 500. However, I already had the 800, which comes with a small but fairly noisy fan. So I decided to replace the fan and heatsink that comes with the board with a Zalman ZM-LB47J Northbridge Cooler which fits it perfectly. I also underclocked the processor to 600Mhz with the jumper on the mobo to make sure it runs nice and cool.
    What else does a file server need? A nice big hard disk. I got myself a Maxtor 200gb disk, and a Nexus Drive-A-Way to keep it quiet.
    The software I'll be running is called SME Server - based on Red Hat Linux. It supplies a very simple-to-manage file server which can be administered through a web interface. I plugged in all my components and a spare CD-ROM drive and installed the OS, making sure it all works:
    The case I'll be using is a fairly plain Maplin box, but I rather like the simple, clean looks, and I will be adding a couple of "touches" to make it look a bit more stylish. Here's the components laid out on the chassis:
    More tomorrow, hopefully! :rock:
  2. kaotic504
    kaotic504 What's a Dremel?
    20 Jul 2004
    that's a GREAT project. i really like how it's coming out. i'd like to build a little file server as well. i was looking at an NAS but those are just too expensive and i have tons of spare parts. problem is the power consumption of using a computer to be my file server. i just want a centralized storage device to upload all my spare data and files and share it among my network.
  3. PirateTheMeep
    PirateTheMeep What's a Dremel?
    7 Aug 2004
    Looking great, I love MINI-ITX mods!
  4. LOTTARO
    LOTTARO What's a Dremel?
    1 Jul 2005
    Subscribed! :D
  5. 3t3rn@l
    3t3rn@l What's a Dremel?
    29 Nov 2003
    id love to be able to afford to make a file server like you are
    its looking great i cant wait to see what you'll do with it
    subscribed
    3t3rn@l
  6. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    Looking good, It's been a long time since I've seen a maplin box modded. They were all the rage at one stage....Been trying to get one for myself, never in stock.
    What PSU is that?
  7. solar
    6 Mar 2004
    It's a long time since I bought it, but IIRC it's a Morex from here:
    http://www.morexintl.com/product/psu_60w.php
    There's a large number of the cases in stock in Maplin at Aintree.
    This project is nearly finished.. I'll hopefully be posting the rest of the log in a few hours :D
  8. solar
    6 Mar 2004
    Part 2
    Mounting brackets for the hard drive:
    Drilling:
    The holes cut for the back connectors:
    Mmm, switchy goodness:
    Test fit of the switch:
    Air hole:
    Test fit of the grill:
    All wired up:
    Another view:
    Finished!:
    Tried to show the awesome LED button:
    Really happy with how this turned out :D :D
  9. Sva4g3&*
    Sva4g3&* What's a Dremel?
    15 Jun 2004
    That is very stylish, but it has no cd-drive? I really like the final product.
    -Rob
  10. solar
    6 Mar 2004
    Nope.. don't have any need for one. I'll have to take it to bits if I need to re-install the software anyway because of the lack of access to the back connectors (unless I can get network booting to work, bloody fiddly!)
  11. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    looks awesome apart from the hole in the top..wtf u just coulda took the top off the heatsink :(
  12. solar
    6 Mar 2004
    It's not just to allow space for the top of the heatsink.. it's to allow hot air out too :eyebrow:
  13. hobbs
    hobbs What's a Dremel?
    24 Jun 2005
    i say take a fiew mm of the hs, i realy dont like the look of the grill =/ or just get rid of the raisers
  14. ellipr97
    ellipr97 What's a Dremel?
    31 Jul 2005
    Looks like a high quality piece of Hi-Fi equipment :hip: :clap: :rock:
  15. solar
    6 Mar 2004
    The more I looked at it, the more I thought you guys were absolutely right - it did look a bit naff with the giant standoffs on the grill. So:
    Looks MUCH better. Thanks for the suggestion :D
  16. atanum141
    22 Jul 2004
    where did you get the LEDbutton from??? and also do u have a maplin no. for that box of yours??
  17. solar
    6 Mar 2004
  18. koola
    koola Minimodder
    11 Jul 2004
    Like the project except for the fan grill.
    Why don't you cut a bigger hole and mount the fan grill on the inside, so it's flush with the top.
    Would look much better and neater :D
  19. huren
    huren What's a Dremel?
    14 Aug 2004
    yeah that would make that apperance wiccky
  20. ultrastapler
    ultrastapler What's a Dremel?
    30 Oct 2003
    taking the hi-fi comment further, why not make a feature of the blowhole and make it look like an old valve amp. the ones that come with cages around the valves like this
    you could even get an orange led for that old valve amp warm glowyness
