Case Mod - In Progress Project N.V. [FINAL pictures and video on page 10]
Discussion in 'Project Logs' started by p0Pe, 14 Jan 2013.
  1. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Hello again guys!
    I was not planning another build, but after talking a bit to a guy going under the nick FabsSPeed, we decided that he needed a not so ordinary primary PC.
    So, without much jibberish, let me introduce
    Project N.V. - A caselabs TH10 FabsSPeed edition​
    N.V. will be a caselabs build, and this short introduction will leave some to be desired, you see I forgot my DSLR at home:wallbash:
    BUT! This will be a mad overkill build and lots of parts will be machined with help from Nate, known by most as Editor22, and 3D printning might occur ;)
    The obligatory hardware list:
    A cpu, a motherboard, a case and some power to run it all. Grafic cards might be added, while harddrives will most likely be found some where.
    But lets get startet!
    First of all, lets start out with this lovely box. What might it contain?
    What madness is this? A US made woman! Naah, just kidding. As I said, my DSLR is at home, so you will have to do with some mobile shots for now;)
    But lets have a look at some of the hardware that will be used.
    CPU
    Mobo
    The wonderful controller that will keep the 24 fans this system will use busy!
    And a small teaser of one of the reservoirs. Some of you might recognize this from my M8 project, but do not wory, the front reservoirs will be bigger and better than the ones in M8 ;)
    And just to give you a little taster of what I will be focusing on in this project, I present you with a modded version of the EK-RAM Dominator X4 CSQ blocks that will cool the ram in this build:
    That should keep Nate busy for a few hours;) I only need a few more parts, and then I can complete that thing, and get it fabricated!
    Deadline for this monster will be: Finish before Pascal AkA Paslis:rock:
    A great thank goes out to the sponsors of this project!
    Its ON!
  2. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    Sounds awesome!
    I'll be following :)
  3. Paslis
    Paslis Minimodder
    13 Jun 2011
    ITS ON !!! :D Lets have some fun mate. :D
  4. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    stick on you head phones and send me the files! I cant wait to get stuck into that monolith!
  5. alain-s
    alain-s Minimodder
    12 Jan 2011
    Teasers are looking grade Hans, GL with the race :D
  6. Si_the-dude
    Si_the-dude Techaholics Anonymous. 0 days clean
    17 Dec 2012
    Definitely going to follow this one. I bet this Caselabs case is amazing to work with!!
  7. l3p
    l3p www.^.nl
    1 Nov 2010
    Certainly following this one!
  8. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    That modded Ram module looks awesome!
    Subbed!
  9. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    Subbed!
  10. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    I caint whait for you two guys to be done with the builds :D
  11. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Awesome!
    I finally picked up a worklog almost from the beginning. This is gonna be good. ;)
    Now, do my eyes decieve me, or does that custom RAM cooler also route water to the CPU and MOSFET blocks?
  12. Guest-23315
    Guest-23315 Guest
    It certainly looks it sir.
  13. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    That all-in-one block looks good,will be watching the fabbing of that.
    My money is on Paslis finishing first tho pOPe...:D
    Now,get to work! :thumb:
  14. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    from the first announce of lga2011 boards i've thought about _real_ FC block for board!
    interesting build!
    *runs for popcorn*
  15. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Oh my A race :D!
  16. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Allright people, place your bets now!
    How will the acrylic be attached to the EK Ramblocks?
  17. patara
    patara life is wonderful
    7 Apr 2012
    :D for what you so this girl?
  18. Guest-23315
    Guest-23315 Guest
    Looks like its bolted straight through to the copper base, with a second layer of acrylic to pass through to give the two channel / two layer look.
    My bet is then solid acrylic/chromed tube from the acrylic section down to a Supremacy block using Bitspower C47 couplers... :D
  19. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    I can't see any of your pictures because I'm at work :waah:
    I don't think I've felt this much emotional distress since I heard Jessica Alba in an interview saying she would never show her knockers in a movie :wallbash:
  20. Cheapskate
    13 May 2007
    Using the ram to anchor the manifold? Cute.:D I do like motherboard manifolds...
    ...as long as I don't have to make them. -then they suck.
    While were at it -Where did you order that woman from? I thought we only had monster-moo-cow sizes available in the US.
