Hey all, Basically, my friend is trying to make a Madden highlights video from his ps2. I believe he is trying to figure out a way to capture the video somehow, then get it on his computer, change it to avi or some format, then compile a video. Any idea how he can get the video? I was thinking maybe he could use a dvd recorder. Haha or maybe point a camcorder at this screen. Any ideas?
You need a video capture card of some sort, plug your PS2 into that and you should be able to do it via that. I don't have much more info but Google is your friend
as opal says, get a capture card. something like the huappuage wintv. it's got a yellow input jack on the back, plug the yellow output cable into it and then you can open it as a video source in your favorite editing program (even windows movie maker works)
