Modding Double red wire into pin for Dell D750E-00
Discussion in 'Modding' started by Mithradel, 13 Jul 2014.
  1. Mithradel
    Mithradel What's a Dremel?
    20 Jun 2014
    At this moment I'm sleeving the cables of my (old) Dell D750E-00 power supply. Started with unpinning all the connectors and writing down where I took the pins out, I'm now at the point of putting them back together into the connector. But I'm stuck at one pin of the 24-pins atx connector, since there is 1 pin with a double red wire instead of one wire, and I didn't write down from which pin I took this double wired, ony that I took a red one out of it. Is there a smarter person than me that can tell me to which pin the double red wired connector belongs?
    Thanks in advance,
    Chris
  2. Teelzebub
    27 Nov 2009
    If you wrote down all the others It will be the one left over
  3. Big Elf
    23 Apr 2009
    Providing Dell follow the ATX standard and the red wire represents 5v (not a given) it shouldn't matter which of the pin-outs you use providing it goes into one of the 5 pin-outs for 5v on the 24 pin connector. You should double check it with a multi-meter or PSU Tester before connecting to your PC.
