Modding LAN Party in a Box
Discussion in 'Modding' started by Full777Metal, 7 Jun 2012.
  1. Full777Metal
    Full777Metal What's a Dremel?
    6 Jun 2012
    This is a project I had planned for a while, but finally have the time and cash to finally start it. Basically its going to be a 50 cal ammo crate with 4x8 port Gigabit switches and a router built in.
    10 Seconds out of the box and warranty already voided, apparently I bought out Newegg's stock of them, because the 4th one is arriving tomorrow.
    Switches removed from case and the ammo crate in the background, there were a few stickers on the case, I'm currently removing them with some Goo Gone.
    Checking the clearance with the standoffs installed, I still need to desolder the power jacks and wire them all up to a single power supply. I'm going to wait for the 4th switch to arrive before starting that.
    Just checking how it looks in the case so far, everything will be mounted to an acrylic cage that will be able to slide in and out of the case as needed.
    Another shot of the standoffs with the switches in action.
    I have been messing around with the idea of using keystone ethernet jacks to tidy up the layout and hide the cables connecting the switch to the main ddwrt router. along with moving the leds and using some nice looking metal led holders for them.
  2. Reconnec7ed
    Reconnec7ed What's a Dremel?
    29 Feb 2012
    Obviously you will need to link the modem and routers via short utp cables. Could look neater if you could plan a way to do this internally? and the same for the power on the routers. Maybe remove the jacks and solder wires in there place. [EDIT: ignore that!]
    Good idea though :D
  3. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    I like this. Are you going to re route the leds so their visible?
  4. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    i say make put everything internal
    the use extenders to make a custom faceplate for all of the ports
    it would look alot neater that way
    you could also wire up all of the wall worts inside as well
    you have plenty of space
    so a crazy idea popped into my head
    WC those chipsets :D
    use the fan hole that you are planning
    and make it a closed loop with no res.
  5. Full777Metal
    6 Jun 2012
    HAHA! Yes watercooling would be epic. I had originally planned on shot ethernet cables, but using extenders like that would definitely look cleaner, I will have to look into that.
  6. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    whats your plans with power your not going to use 3/4 AC adapters are you ?
  7. Full777Metal
    6 Jun 2012
    I'm going to desolder all the power jacks off the boards and get a higher amperage power supply and run everything off one. It would definitely be way too messy using multiple.
  8. Full777Metal
    6 Jun 2012
    Just a quick update, the 4th switch came, so i decided to test fit them on the acrylic mounting tray I made.
    Switch 1 mounted
    All 4 on now
    I had originally planned on installing it facing this way then running cables directly to the ports on the faceplate.
    I'm throwing around the idea of just having the leds visible with the switch facing this way, that way it will hide the ethernet cables running to each jack.
  9. Andy Mc
    Andy Mc Modder
    23 May 2002
    Would it not look better if the switches were rotated 90 degrees? Or is the ammo tin too narrow?
  10. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    This is such a cool idea.
    Mass produce them I'd buy one.
  11. Panomama
    Panomama I once signed up on uniform dating
    11 Jul 2009
    Great idea,
    What about putting a raspberry pi inside it too? Then you can also have a desktop wherever you take it, or for a small server.
  12. ninjaplease
    ninjaplease I don't know what I'm doing
    11 Jan 2012
    I would love some measurements/parts list for this, I've got an ammo tin being used as a toolbox atm and this would be epic.
  13. Andy Mc
    Andy Mc Modder
    23 May 2002
    another suggestion. If you do go the custom front panel routew then I would suggest plugging each of the switches into a different lan port on the router, so that you can setup vlans to segregate the network if needed (so you could have an admin LAN, console LAN and a PC lan etc).
  14. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    Sub'd
    Always wanted to do something like this
  15. adrock
    adrock Caninus Nervous Rex
    5 Dec 2006
    this looks pretty cool. i agree with the suggestion for a raspi in there, offering some basic services that aren't covered by your router, maybe even add a HD to provide a central location for file sharing at a lan party? just spitballing, but you could try some kind of accessible disk caddy under the hood? it looks like you've plenty of space to play with.
  16. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    Go internal otherwise you'll need 4 external jumper cables to connect the switches and router together.
    Get one of these; you can actually take the individual 6 port modules off the rackmount. It will be a mess of wires inside, but harmony on the outside.
  17. Guinevere
    Guinevere Mega Mom
    8 May 2010
    But externally visible patch cables on a project like this will look cool!
  18. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Considering how hot my D-Link & Alcatel switches get during LAN parties I think you might want to increase airflow or direct it across your switches.
  19. Guest-23315
    Guest-23315 Guest
    This is awesomesauce :thumb:
