Case Mod - Complete [Thermaltake Core P5] MILK on the Wall. 20.02.2016.
Discussion in 'Project Logs' started by Cown, 20 Feb 2016.
  1. Cown
    Cown Minimodder
    25 Feb 2012
    MILK on the Wall
    Hey guys
    Time for another build :D
    After discovering the Core P5, I immidietly fell in love with the case and decided that this would be the base for my main gaming rig.
    The color scheme will be BLACK, WHITE, and RED.
    I am of course, using liquid cooling in the build :)
    Now I've cheated a bit, and have been working on this along side my other, recently finished, project.
    Now on with it :dremel:
    The hardware:
    • CPU:Intel Core i7 2700K
    • MOBO:ASUS MAXIMUX V GENE
    • RAM:Corsair Vengeance 16 GB DDR3
    • GFX:EVGA GeForce GTX 980 Ti SC+ ACX 2.0+
    • SSD:SAMSUNG 850 EVO 250Gb
    • HDD:Wester Digital WD15EARS
    • PSU:Cooler Master V1000 PSU
    • CASE:Thermaltake Core P5
    The cooling:
    • CPU:EK Supreme HF
    • GFX:EK FC Titan X
    • RAD:HW Labs Black Ice GTX 360
    • PUMP:Laing DDC 1T Plus 18W
    • RES:EK DDC X-RES top
    • FITTINGS:EK HDC
    • TUBE:EK PETG
    • FANS:Phobya Nano-2G
    • CONTROLLER:NZXT Sentry LX
    • COOLANT:Ice Dragon Cooling Nanofluid WHITE
    I've chosen to show the unboxing of the case, since I had a hard time finding decent pictures when reading reviews, so I though some of you might find it interesting :)
    Unboxing the Core P5:
    Feet and standoffs:
    Back:
    Front:
    Inside, as seen from the back:
    All this was crammed inside the case:
    Manual:
    Spacers, for the backside of the case, when wallmounting, these will of course be used:
    Front again:
    Mounting brackets for PSU:
    Going to be used on this baby, the CM V1000:
    Rubber washers, strips, screws, pc speaker etc:
    Mounting the PSU:
    Motherboard mounting screws, along with a top for easy installation:
    If one should have any doubts:
    Screws:
    Mobo mounted:
    The feet for the case:
    These were tucked inside:
    Holes for aligning the feet to the case:
    Unfortunately not all types of screwdrivers fit, in this case my Bacho with magnet feature.. Really was a ***** to mount without it, screws kept falling off and inside the feet :-/
    Done:
    3.5" mounting bays for harddrives:
    Samsung going to the front line:
    WD going under cover:
    Mounting holes for SSD, but only for one:
    Mounted, as seen from the back, the M3 screws used, were not included, got these from MDPC-X some time ago:
    Front:
    Mounting the WD:
    GFX mounting brackets for vertical view/mounting. This is a REALLY nice feature IMO:
    PCI-E extender:
    Getting there:
    GTX 980 Ti :D
    Fits perfectly:
    As seen from below:
    PCI brackets:
    Now I don't really like the design of these, so am goint to change them with some aluminum ones from Lian Li:
    Just for fun, I tried to weigh them, to find out if there was any difference:
    20 grams in total, well I guess everything counts when it's going on the wall :D
    Test mounting the fan controller and radiator:
    Unpacking the standoffs for the acrylic window:
    These puppies are HEAVY and Shiny :D
    The window, with protective film:
    Mounted and ready to go, until the ordered LQ parts arrive :)
    DDC Pump:
    Sleeved:
    Fans:
    Sleeved:
    X-Res top for DDC:
    PETG tubing and some of my HDC fittings:
    EK Anti-vibrating kit for DDC + mounting plate:
    Mounted:
    EK HDC, I'm still missing my T-splitters and fillport :wallbash:
    Supreme HF, as is:
    Mounted:
    FC Titan X, D.I.Y. bending kit fra EK and Ice Dragon cooling nano fluid, MILKY WHITE of course :D The liquid is just beautiful :jawdrop: well worth the money.
    Unboxing the D.I.Y. kit, I've found that the silicon could have been longer. It would have made, bending more complex easier.
    GFX ready to get stripped naked:
    FC Titan X:
    NUDE :jawdrop::
    Done:
    Modded Supreme:
    Color of all sides of the case changed to white:
    Fans :) Radiator moved to the top and controller to the bottom:
    FC Titan whitened:
    Same with PSU:
    Last of my fittings have finally arrived:
    Fillport:
    Bending and mounting the PETG. I've found that 350° celsius was the most fitting heat for this :)
    All done with the tubing:
    Fill her up laddy :blush:
    Some pictures of the finished build:
    Next up, mounting it to the wall and final pics :thumb:
    Thanks for looking guys, I hope you liked it :dremel:
  2. hodge74
    hodge74 What's a Dremel?
    3 Feb 2016
    Jaw just dropped to the floor .
    Very sexy. .. well done great building
    Sent from my SM-N910F using Tapatalk
  3. Donnii
    Donnii Mods By Donnii
    15 Jul 2015
    Looks great :)
    Im working on a build in the same case :p
  4. Cown
    Cown Minimodder
    25 Feb 2012
    Thanks mate, really appreciate it! :clap:
    Thanks :D I just had a look, it's coming along nicely!
  5. Cown
    Cown Minimodder
    25 Feb 2012
    Update 25.02.2016 - Night pics
    Hey guys
    Here are a couple of pictures in the dark:
    Really hope you like it :)
    As always, thanks for looking :dremel:
  6. Cheapskate
    13 May 2007
    Nicely done. -That title, though...:lol:
  7. Cown
    Cown Minimodder
    25 Feb 2012
    Thanks :D
    LOL, I didn't even think about it before you said it. You have a very dirty mind :naughty:
  8. Mr_Armageddon
    Mr_Armageddon Minimodder
    31 Jul 2009
    I like it! Great job with the build. I am working on a build using the same case. Glad a manufacturer finally made this kind of case, and that it was reasonably priced.
  9. storm-83
    storm-83 Minimodder
    7 Nov 2014
    <sorry for the Danish>
    hvornår er sidste holdbarheds dato? :eyebrow:
    </sorry for the Danish>
    nice build and color scheme :thumb:
  10. Cown
    Cown Minimodder
    25 Feb 2012
    Thanks mate :) yeah I was positively surprised when I saw the first review for the case, made me wanna do something with it :D
    Hehe, well the technology for pasturisation and homogenization is at its peak, so hopefully not for a long time :D
    Glad you like it, thanks for looking :)
  11. CaseLurker
    CaseLurker What's a Dremel?
    15 Mar 2016
    Wow! That black and white is super slick!
    I would love a build exactly like this except for different fans.
    Awesome mod.
