How to insert folding stats in your forum signature
Discussion in 'bit-tech Folding Team' started by Lizard, 23 Apr 2009.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    All credit for this thread should go to pomeroyip, as he set up the original thread on the old Custom PC forum - I'm simply recreating it here for continuity.
    As this question gets asked so often, here is how to do it:
    To add your stats to your sig enter the params surrounded by the [folding] tag into your forum profile sig box.
    Example:
    {param}
    You can get your folding username from the end of the URL on http://folding.extremeoverclocking.com
    i.e. http://folding.extremeoverclocking.com/user_summary.php?s=&u=83772
    souper82 and rOBvAN like this.
  2. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Except that the bit-tech forum doesn't allow images in sigs - unless it's possible to change that on a section-by-section basis?
  3. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Good point - thanks for reminding me of that.
    We'll do some behind the scenes work and see what can be done.
  4. kenco_uk
    28 Nov 2003
    I guess when you change team, you have to let it do a unit before new stats come up?
    edit: yup ;)
  5. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Sigs now working in this forum. I've edited the first post to reflect what you need to do.
  6. JackOfAll
    JackOfAll What's a Dremel?
    23 Apr 2009
    Jamie, is there something else I need to do, other than > 10 posts? I still can't see anywhere to add a sig in the CP.
  7. Jamie
    12 Mar 2001
    The promotion is only run every hour at 45 minutes past the hour, you'll have to wait 3 more minutes.
  8. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
    AFAIK, yes. Plus the Folding stats only update every 3-5 hours.
  9. JackOfAll
    23 Apr 2009
    Testing sig ......
  10. Sifter3000
    11 Jul 2006
    You need to make sure there are *no* spaces in the code (i.e. the stuff in square brackets)
  11. JackOfAll
    23 Apr 2009
    Thank you!
  12. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Testing.
    Yay!
    Why are there different colors?
  13. Sifter3000
    11 Jul 2006
    Where abouts? You can change the colours of the forum in your user CP, but that's just a preference...
  14. 500mph
    22 Jun 2007
    The different colors of the folding stats
  15. saspro
    saspro IT monkey
    23 Apr 2009
    The colours change depending on how many points you produce
  16. kenco_uk
    28 Nov 2003
    Go to User CP (on the blue bar under the thread heading), edit your signature and then add the folding tag into your sig.
  17. Thaifood
    Thaifood Minimodder
    24 Apr 2009
  18. Majik
    Majik Another CPC refugee
    24 Apr 2009
    It's good to be here and let's hope we have a great future together!
    :rock:
  19. denis6902
    denis6902 deathbox
    28 Sep 2008
    testing sig, lucky you guys, just reinstalled vista and the newer 64bit ubuntu 9.04 and its all set for folding again! Lucky because i am going to contribute for this team!
    I guess sig didnt work, now it does!
  20. denis6902
    denis6902 deathbox
    28 Sep 2008
    btw, when are the lazy bones from standford going to make a gpu folding in linux? not even going to mention xbox360
