Hi guys is the GA-790XTA-UD4 motherboard compatible with NVIDIA cards? As I only see information about ATI and crossfire on the manual
I have the very same mobo. I do not see why you can't use NVidia on this board. It has 2 available PCI-e slots. This is an AMD CPU board so you can't fit intel or anything - but it does not say it can't work with NVidia. I have 2 AMD 5770 cards purely for cost and I wanted an AMD/AMD setup. I love the motherboard and would happily put an Nvidia card on it if I decided to. But maybe someone from Gigabyte can tell you otherwise. The manual only mentions ATI cards and crossfire-enabled. I am just assuming it will also take SLI but that is not 1,000% ==> http://download.gigabyte.eu/FileList/Manual/mb_manual_ga-790xta-ud4_e.pdf *UPDATE: just googled and common consensus is 790x chipset won't allow SLI, only Cross-fire. So you can put a single NVidia card in, just not 2!!
