PSU What size PSU for this upgrade?
Discussion in 'Hardware' started by dadoftriplets, 4 Apr 2015.
  1. dadoftriplets
    dadoftriplets What's a Dremel?
    14 Feb 2012
    I need a new PSU for an upgrade to my current rig. The new build is going to be
    i5 4690K
    Gigabyte Z97 board - not decided which,
    AIO water cooler - Either my current H80 or the larger H110 - not decided yet
    R9 270x.
    I have looked at the PSU estimators which say this will need a 550 watt PSU, but I stumbled upon a video which says that I should be adding a further 150 watts on top to provide overhead which has really confused me???
    FWIW, my current PSU is an OCZ Stealth2 something 600 watt which is going into my kids build which currently needs a new PSU (thought I'd upgrade my PSU instead :) )
    I am going to be overclocking the CPU as well if this adds in anything and I am looking at either semi or full modular PSUs as well
    Any advice and recommendations would be gratefully received.
  2. The_Crapman
    5 Dec 2011
    550w will be more than enough for your rig.
  3. Deders
    Deders Modder
    14 Nov 2010
    Agreed, I expect the calculators already added the extra overhead into the equation.
  4. Shirty
    18 Apr 1982
    As above, even a decent 450W unit would suffice.
  5. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    I'd get a 600w unit, it'll give you a bit of margin and it'll still be fairly cheap. Something by Corsair, Enermax or Silverstone would be good.
  6. edzieba
    edzieba Virtual Realist
    14 Jan 2009
  7. dadoftriplets
    14 Feb 2012
    Sometime in the next 6 months I will be upgrading the the GPU from the 270x to something in the range of the 280/280x - 290/290x or Nvidia ??? - will the 550 be enough for this additional upgrade or would it be better to go for the slightly larger 600 watt?
  8. The_Crapman
    5 Dec 2011
    When I was running a core2quad and gtx 480 both with hefty overclocks, i was pulling less than 450W, so 550 would still be more than enough with one of the gpu's you mentioned.
  9. dadoftriplets
    14 Feb 2012
    Thanks - one final question. Is there any reputable brands i should avoid? And any I should consider?
    I have been looking at the Cooler Master VSM650 Semi(Hybrid) Modular PSU as it seems decent and is well backed with a very good 5 year warranty. other than that one, I'm not entirely sure what brands to go for, apart from Corsair that is.
  10. edzieba
    14 Jan 2009
    Easy way is just to go for PSUs with an 80+ certification.
  11. ak_2020
    ak_2020 Minimodder
    22 Nov 2010
    a Corsair CX 500 should do alright. 80+ bronze rated, and cand be had for less than fifty quid. Or for a few extra quid you can get the semi-modular version (CXM 500)
  12. dadoftriplets
    14 Feb 2012
    thanks for the recommendation. I'll take a look in the morning.
    edzieba mentioned to go for anything with an 80+ rating - Scan have some PSUs by a company called Powercool which are listed as being 80+ rated, but are less than half the price of a brand i recognise - Are these PSUS likely to be as bad i think they are without trying them or is it an OEM brand i've never heard of (not that i would buy a PSU as cheap as that as you get what you pay for)
    As an example
  13. edzieba
    14 Jan 2009
    It's not listed by 80+, so it looks like Powercool are telling porkies.
  14. Deders
    Deders Modder
    14 Nov 2010
  15. dadoftriplets
    14 Feb 2012
  16. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    Great purchase, I've just bought a similar XFX one myself. Yep, it's a rebadged Seasonic :)
  17. silk186
    silk186 Derp
    1 Dec 2014
    650w is what I would have gone with.
