Error Message I do not understand
Discussion in 'bit-tech Folding Team' started by ArthurBuse, 9 Jan 2014.
  1. ArthurBuse
    ArthurBuse CustomBitChimps member
    26 Apr 2009
    What should I do about this error message? It is still folding, judging by the CPU it is using.
    Reading file work/wudata_04.tpr, VERSION 4.5.1-dev-20100930-afd66-dirty (single precision)
    [15:26:58] Mapping NT from 4 to 4
    Starting 4 threads
    Making 1D domain decomposition 1 x 4 x 1
    starting mdrun 'GROtesk MACabre and Sinister in water'
    195000000 steps, 390000.0 ps (continuing from step 194500000, 389000.0 ps).
    [15:27:00] Completed 0 out of 500000 steps (0%)
    NOTE: Turning on dynamic load balancing
    Warning: 1-4 interaction between 22326 and 59427 at distance 2.855 which is larger than the 1-4 table size 2.200 nm
    These are ignored for the rest of the simulation
    This usually means your system is exploding,
    if not, you should increase table-extension in your mdp file
    or with user tables increase the table size
  2. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    If the WU falls over because the simulation cannot continue on the trajectory, it would normally stop and send the results back, before then downloading a new WU. Just keep an eye on it - if it doesn't progress over time, then stop the client, delete the WU, and restart the client.
  3. ArthurBuse
    26 Apr 2009
    Thanks. The work unit is progressing and is now at 13%
    Update: unit complete. 4,485 points.
