So I'm building a desk case that will have a triple monitor setup. I'm planning on a 1440 monitor setup and I believe the monitors are around 9# each. I plan to have just a straight 2" aluminum tube coming out of the back chamber of the case where all of the wires & PSU is. NOT an additional attachment to the back of the case like I've seen some do with the Red Harbinger case. Is there any type of mounts that I could then attach to the main 2" pole, or should I just have the fabricator make a T bracket of some kind out of aluminum 2" bar? Trying to keep it light, but yet strong so aluminum should do just fine. I'm just not sure if there's something already on the market that I could add to the main 2" round pole instead of having to try and fabricate movable arms.
