Hello everybody, I present to you my new scratchbuild project named " renovatio mark 1 " , renovatio mean renew in latin and why i choose this name ? because the first idea of this project is to create something new but without change the existing things and mark 1 because this is the first bench table i do . I tell you the story , there are six months of that, I was looking for a bench table "cheap" but "design" to test the components I had in stock , I found things on the internet but at so expensive prices ... Anyway I decided to imagine a " one is never better served than by oneself " the first goal of the maneuver was to quantify the design of a table custom bench and see once modeled if the project is interesting or not . the second objective was " easy integration watercooling ." I started in the plans in 3D Solidworks and after six months of planning and testing, I released this: Top view : light gray clutter of a motherboard ATX Bottom view : side view : https://lh4.googleusercontent.com/-...-I/AAAAAAAAD5o/O_5u8Vy-b2M/w800-h406-no/4.jpg Vue isometrique : All gray blocks that you can see inside are the pump and power supply , I plan supports for the pump , radiator, power and SSD, I show you once received . The model measures 47.3 cm x 47.3 cm x 15 cm. The basic configuration will be unveiled shortly. I sent all cut from " johnsteelpro " in France I shall have to do the folds and seams . It cost me € 180 including shipping to those interested a small dot on the config [ [] ] : and a sponsor follow me , thank you to " EK watercooling " here are the pictures all parts have been folded by a professional " family thank you " I confessed that I had a strong emotion when you see everything taking shape like that while this was an idea. here are the photos : I'll see if it all could be sealed today. See you.
hello, I spend tonight bring news , today there is a strange thing happened in my office I decided to give food to my old PSU that was to serve me ... for this mod is that it eats well it's the little beast . and boom... I'm kidding . A big thank you to Bequiet [/ b] for this wonderful participation adds that this 4 ventilos Bequiet shadow wings in perfect 120mm radiator for the project . - Assembly of all the components is made : mother board power supply SSD Pump Rad Tanks switch on/off the protection of this switch I have a few modifications : - Insert one of the tanks is still top of the blow one of them is slightly inclined I retravaillerai tomorrow . - The plate of SSD to deliver 90 degrees. I also add feet project that I will double in caoutchou to avoid scratching the tables already and to create a slight thickness so that the bolt does not touch the ground. I shall have to go up the watercooling but I await news . and do the painting , I think based on the green and black " view can be a nvidia logo " . to see, unless you have better ideas , I was listening. @ see you soon.
