Hi everyone. Welcome to my project "LEGACY". As you might guess from the title of the project is the subject of TRON Legacy. A huge THANK YOU to the sponsors who support this project: Model:
Motherboard: MSI B85M-G43 Video: MSI GTX 960 2GD5T Memory: AVEXIR - DDR3 Core Series - Quad Channel Kit Power Supply: Thermaltake Toughpower DPS G 1050W
Completed design cooling the graphics card. Dismantle the nominal cooling system Installed on the CNC machine to measure the heights of chips. Full cover water block. Picked up piece of plexiglas Milling form Tapping Сopper heatsink Rubber spacer Nozzle Assembly Finally testing
Design cooling the CPU for LGA 1150. Make Waterblock for CPU. Milling of copper heat sink Milling brass spacer Plated with rhodium and gold. This is result. Picked up two pieces of plexiglas Glued together Milling form Result
It's time to front. Rack access. The basis of the front panel. So, the process of creating the front panel. Milling. Holes nuts. Undercoat... Caulking... Painting...
Byke time. Sliced workpiece from plexiglas glued Milling optical fiber filled epoxy block pulled out of shape Milling byke Сold enamel in the processing good material for a long time ... In this case there is no practical value shall only to impart the required form. small video light byke
It`s the cooler time... Install coolers install radiator and sleeving Completely assembled bottom of the case top inset assembled top panel Install coolers Completely assembled top of the case Painted and assembled of the case
Mount motherboard the motherboard on the site with CPU waterblock Panel mount video on the site Fix the power supply sleeving Distributing water with pomp and together reservoirs The Wave Build and sleeving
Sorry that last batch or two of photos are way too large and not all of them even load. Please RESIZE them thanks ! Otherwise excellent interesting build, carry on with the quality work
Temperature Sensors And small video. PCB top light Cubieboard I set the card to play two video streams. The front panel and the side window. SSD Mount SSD Continie sleeving UV led strip set the grid laid pipes Ending sleeving Electroluminescent Panel Test the light Left and Right panels Stickers And small video of filling
