Graphics New graphics card for an old rig
Discussion in 'Hardware' started by freshsandwiches, 17 Oct 2013.
  1. freshsandwiches
    freshsandwiches Can I do science to it?
    9 Aug 2009
    Hello,
    I built my current rig in 2007. It has served me well and only the motherboard and graphics card have been replaced since then by RMA.
    Would it be worthwhile purchasing a newer GPU for it? Clearly it wouldn't be a good idea to buy the latest and greatest card, but something that would match my current spec which is in my sig.
    Thanks in advance for suggestions.
  2. jizwizard
    jizwizard Modder
    24 Dec 2010
    Probably something along the lines of maybe a 460gtx or 560 non ti would work well. Or maybe something a bit more low end on newer models
  3. mrbungle
    20 Sep 2004
    Pick up a 2nd hand q6600 and u fill find you won't bottleneck midrange cards too badly. A 7850 or 7870 would still be decent backed by a quad.
  4. jinq-sea
    15 Oct 2012
    I'd agree with mrbungle - Q6600 in, turn up the volume and drop in a 7870 (or 660Ti) and you'll be laughing! :)
  5. freshsandwiches
    9 Aug 2009
    Thanks for the suggestions. I didn't think to upgrade the processor. A q6600 can be picked up on ebay for about £45.
    Might just keep my existing processor and get a cheap card for about £100.
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    imo just get a higher end card so that you can move it over to your next rig without it being wasted long term in your current PC once it's retired
  7. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    +1
    Or even a 7850, those things can overclock like crazy.. Had mine running at 1150 MHz stock volts.. Pretty much the same speed as a 7950
  8. Thermolance
    Thermolance What's a Dremel?
    19 Sep 2013
    I would say have a look at our weekly deals, We might be able to help you out this week with a decent HD7850 at very decent prices.
    Yoyotech.co.uk yellow tag offers
  9. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    GTX TITAN in SLI should sort u right out
  10. Pete J
    Pete J Employed scum
    28 Sep 2009
  11. The Bear
    The Bear What's a Dremel?
    19 Sep 2013
  12. stefan442
    stefan442 Minimodder
    14 Mar 2011
    My q6600 does me well... but I am looking to upgrade soon. 1920x1080 bf3 high settings I got about 30fps.... on pc in sig.
    Will have to overclock a but more for bf4 me thinks, and oc the gfx card as well. I am looking to upgrade but im going to see how I perform in bf4 first.
    Also I am thinking a ssd will do for short term fix!!
