Other Calendar software
Discussion in 'Software' started by Ren, 19 Oct 2011.
  1. Ren
    Ren What's a Dremel?
    7 Nov 2008
    Hi all,
    I am looking for a good calendar software!
    I need to put my uni timetable in so it will be the same each week and they I can add bits and bobs to the calendar, for example when assignment are due in or something like that.
    I wanted to try google calendar but I cant seem to find how I can enter my timetable once and not just put every module again and again every week if you know what I mean :/
    So, do you guys know of any good calendar software where I can organize my time?
    Thank you.
  2. Guinevere
    Guinevere Mega Mom
    8 May 2010
    1. Start google calendar
    2. Double click to create a new event. (Or click once and then click "Edit event")
    3. Click the "Repeat" check box.
    4. Set up your repeat schedule (Weekly, monthly etc)
    5. Eat a donut as a reward for setting up a repeating event.
    6. Hand out the rep here in the forum.
    Ren and Teelzebub like this.
  3. Krikkit
    21 Jan 2003
    :thumb:
    Ren likes this.
  4. Ren
    7 Nov 2008
    Awesome!
    Thanks for help guys:)
  5. Ren
    7 Nov 2008
    Would it be possible to sync with android calendar? Or some app required?
  6. wolfticket
    19 Apr 2008
    afaik it syncs by default if you use the same Google account for your phone and your online calendar.
  7. Krikkit
    21 Jan 2003
    This ^^
    My phone syncs to my google calendar which is immensely useful, and the downloadable add-in calendars from others make organising incredibly easy.
    Once you've finished your uni timetable make it an exportable calendar and share with your coursemates!
