Modding Silent Fibreglass PC by Keir Graham
Discussion in 'Article Discussion' started by Claave, 18 Jan 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. mi1ez
    mi1ez Modder
    11 Jun 2009
    Is it my imagination, or are there 2 different PCs in there in different shots?
    Either way, an awesome build! good work.
  3. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    iirc he changed the design a bit towards the end.
    As is prone to happen on most projects :D
    this was fun to follow, happy to see it on the front page!
  4. BlackMage23
    BlackMage23 RPG Loving Freak
    4 Aug 2006
    Very nice, but that DVD drive ruins the look a bit on the side.
  5. death_munky
    death_munky F*** the dremel, i'll use my teeth
    5 Nov 2008
    What a great project on a tight budget. I think the final result looks really good and the finsh is excellent (fibreglass is a proper PITA to work with)
  6. Cyberpower-UK
    Cyberpower-UK Professional Overclocker
    6 May 2009
    That is a really nice looking system. Did you ever consider fitting a screen instead of a door?
  7. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Honestly, (not sour grapes, before anyone insists about it) if I had access to such equipment I think I probably would have done something like that. DnT class in my secondary school only gave me access to small small planks of wood and wood working machines. Hardly the most efficient way of building a casing.
    Not to mention how irritating it would be if the wood warped and wrecked my PC. Near the end of the DnT course spanning 2 years we had access to metal... Small pieces of metal smaller than a name card. While admittedly a PC built out of such materials would not only be amusing but amazing, I am not one blessed with patience. :X
  8. Zero_UK
    Zero_UK What's a Dremel?
    12 Aug 2008
    That does look amazing, a shame that the actual hardware had to be budget :(.
    Looks fricken sweet though.
  9. benji2412
    benji2412 <insert message here>
    25 Apr 2009
    I'm pretty amazed you managed to get an AMD Athlon 64 X2 to 4.6 GHz. How'd you manage that one? What are the temps like?
  10. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    If you could or can find an slot-in drive, that would me much pleasing and follows the looks on the side.
    Great thing done there and lots of dedication. As cyberpower-uk said, I also thought of a screen in there instead of a clear acrylic but that would have increase the dimensions and cramp the space a little so it was good you didn't do it. And some cable tidying would be more pleasant to the eye.
    Lucky for having such equipment at your disposal, great job
  11. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    This case makes me happy.
    And apparently itself as well. :)
  12. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Thanks for all the comments everyone :) I seem to have missed the PC specs the ones listed are my old set up, my new set up is:
    Full system specs:
    CPU – Intel Core 2 Quad Q9550 @ 2.8ghz
    GPU – Radeon HD3850
    CD/DVD - Samsung dual layer DVD/CD writer
    Hard disks – 1TB Samsung 7200 rpm, 120Gb Samsung 7200rpm
    Memory – Corsair Dominator DDR3 1600mhz 6GB (3 x 2GB sticks)
    Motherboard – MSI X48C Platinium
    Powersupply – Colorsit 550w with modded 12cm rubber mounted silent fan
    Water-cooling – XSPC Laing DCC (18w) with acrylic top, Zalman ZM-WB5 CPU block, Zalman ZM-GWB3 VGA block, clear 10mm ID 15mm OD tubing with a custom made radiator.
    The temps are 30C idle and around 45C while cherning through Supreme Commander - FA at 1920x1080 , the GPU is also overclocked to 705mhz from 668mhz.
    I thought about having a screen in the case instead of the panel, however I wanted a much larger screen than one that would have fit in, so I decided to have the parts visible instead of a secondary screen. Some of the pics at the end are of the old version of the case which didn't have a nice interior and the paint wasnt anywhere near as good as it is now. My school was also terrible with the supplied DnT facilities most of the machinery and materials I used where from else where.
    I think I've answered everyones questions :) Please feel free to ask more.
  13. VaLkyR-Assassin
    VaLkyR-Assassin Minimodder
    16 Feb 2009
    That's really impressive work to create that case - it's great to see the photographs of each stage to see how you turned the raw parts into a beautifully crafted piece of art.
  14. Freedom
    Freedom Minimodder
    27 Oct 2004
    Nice case. Screen shot of the temps please not entirely convinced by the cool arrangements though.
  15. woodss
    woodss Yes Louis Wu
    19 Jan 2010
    Understatement...fibreglass is the ultimate PITA to work with...itd be easier to make the thing out of clay.
  16. riekmaharg2
    22 Feb 2009
  17. woodss
    woodss Yes Louis Wu
    19 Jan 2010
  18. akibro
    akibro hmmm....
    15 Sep 2009
    I'm suitably impressed! good work with what you had available! I will always admire someone with patience enough to make a case like that, makes me wanna think about doing something again
  19. Abdul Hadi
    Abdul Hadi Technically, I wanna be tim!
    6 Aug 2009
    Great Paint finish Man. I'm really impressed. Practical approach to cooling. Though I find the inside of the case asthetically mmmmmmmmmmmm.......... Boaring. I mean not beautiful. better be a plain finished paint.
  20. riekmaharg2
    22 Feb 2009
    Thanks akibro, and abdul, the main reason the inside isnt as good as the outside is because I only planned to make the inside visible very late into the build, so by that point there wasnt much that I could do unfortunately.
Tags: Add Tags
